So your average consumption is 27kWh/100km, no matter the conditions? Ouch 🤕
Mine is 26kWh, 80% of the time on highways (120-145 km/h), always cold weather, rainy, and lot of time idle with me playing in the car, often 4 people in the car and 22’’ wheels.
Only 2000 km so far since end of November.
mikeright
mikeright
Spain
BMW
Electric Macan EV From Hungry to Efficient: When Did Your Macan EV Start Becoming More Efficient? Screenshot 2025-01-27 at 18.55.27
Same 20 mile range drop in my BMW iX, i.e., I eft my roughly 70 degree garage with 174 mile range but by the time I had gone 1 mile it was 21 miles less.
timps
tim
Porsche Macan 4s
At around 900 miles after some heavy breaking regen started to appear and efficiency improved.
Good to know.
Is heavy breaking necessary to achieve improved efficiency?
I tend not to do that as I understand regen works better for efficiency and the regen works first when braking, and heavy breaking uses the actual breaks 🤔
timps
tim
Porsche Macan 4s
Made me think it was waiting until satisfied that the breaks were bedded in. I don’t think that heavy breaking is a necessity. I was just showing car off to friend.
wmras
Bill
Oregon
Here is our total consumption after 8000 km with the first 6500 km from PEC ATL (Atlanta) to Portland, Oregon. Average load was 240 kg, temperature was -5C to +8C, altitude from sea level to 2134 meters (more than 30 mountain passes). Last 1500 km have been local in Portland, Oregon with 160 kg load. Consumption in Portland at similar temperatures is nearly identical to total from start.
Electric Macan EV From Hungry to Efficient: When Did Your Macan EV Start Becoming More Efficient? 1739732743417-w4
One thing is for sure... the efficiency in temperatures ABOVE 45f is night n day.
Over winter, i was able to acheive around 2.5-2.8 mi/KwH with some occasional trips hitting 3.
but once the temperature in my area hit 45+ ... the efficiency jumped. 50-60* weather is netting me 3.4 - 3.6 mi/kWh!
Begs the question why Porsche didn't launch this car in warmer weather so that the press releasess would be more favorable on the range discussion!
