2026 Software Update via Dealer - What does it do exactly?
Tblue87
NJ USA
25 Taycan 24 Macan 4
It is very clear WSJ0 = VR28.13
What @craz8 above says is true.
Update is exactly the same as released 7 months ago.
Zero 2026 features made it to 2024/2025 models.
Is this the update that is causing the home ac level 2 charging issues?
pm4s
It's not like there are several updates.
VR28.13 is the last update.
VR28.11 is the previous update that was installed during PDI for my Macan as I am sure for most as well.
If you have no issues and want to play it 100% safe you may delay the update to VR28.13.
While the update is the same, as dealers do more & more updates on guinea pigs/lab rats/ customers cars they are less likely to fry a module or 2 (happened to me on a different update).
Just to add perhaps more confirmation, when I dropped of the 4S this AM to get caught up on service campaigns, the order included WSJ0 , update to version 28.13.
If you read through WSJ0 posted elsewhere here you will find install instruction revisions corresponding to pauses. Better instructions that may reduce the number of bricked modules (AKA computers). Its always been the same big software package (lots of different computers)
I would not be surprised if the PCM UI changes that bring MY2026 changes get delivered OTA. It seems the various ECU and control unit updates need to be dealer updates, but they’d probably be a dependency for the UI updates. Anyway who knows, we’ll see what happens.
My opinion is that this is what is going on. Update the core systems to 28.13, followed by a set of OTA PCM application updates to the latest UI. Info such as battery State of Health is likely not available to the UI without the 28.13 update.
I don't know how the dashboard UI is handled in Android Automotive, but all the PCM top level buttons are individual applications that can be updated OTA. The Porsche internal ones are handled slightly differently to the third-party apps, as they don't appear in the App Store, but the process to update is the same.
I've worked in hardware/software/subsystem integration for vehicles for decades. Companies do not typically have the capital to get something like a car or truck to market in time so partners and vendors are assembled to get it done. Each is different and have different software maintenance.
You would think that in an ideal project, everything is developed in house. But then then there can be issues and there is quite a bit of risk. Rivian would be dead now if it wasn't for all that Chinese capital backing them up. Tesla uses their customers for betta testers, an approach that saves money, but makes for a unpredictable and inherently flawed product.
Porsche doesn't seem to be doing anything different than large conservative companies. I'm seeing some naivety posted here for software/firmware maintenance for these kinds of integrated platforms. The subsystems may continue to evolve and improve and easiy updates. But WSJ0 appears to be a big network architecture change cut across a dozen subsystems that have to play well together.
Anyway it is not as easy as the armchair quarterbacks here seem to imply, they just don't know what they don't know.
And it does seem that 28.13 had to happen before improvements to smaller apps or subsystem can happen which very well could be OTA.
MatC21
I like your optimism. OTA Updates 🤣
I stand my point from the first page, I would be very much surprised if we ever get any significant update, especially for MY24 and MY25.
my prediction no "meaningful" OTA updates (anything beyond PCM) for current generation Macan EV's - maybe with a 2028 .2 refresh - but even that I give low odds to - the next full generation of Macan EV (if there is one) will have greater OTA capabilities…
my $0.02 worth…
Tblue87
NJ USA
Makes sense, thanks
dwauch
Santa Monica CA
2025 Macan EV
and people wonder why Porsche doesn't have OTA updates…I'm reading the first few pages of the updates instructions posted on this thread…
  • you need the vehicle on a 90 amp 12V charger during the update process (1 kW power supply - seems about right to run all the on board electronics during update)
  • can't and do not sit in the vehicle while it's happening
  • "Destruction of control units" <----- my personal favorite line from the whole tech bulletin :oops:
  • don't mess with the ignition while it's happening…
  • don't do it more than once unless it fails…
I remember these sorts of update instructions for stuff I was playing with in the 1970's…
Yikes. Yes - that doesnt sound good. Interesting spot. I bet there is more good stuff. kind of like digging into the epstein files. ooof. Not pretty.
I've seen this often in highly regarded name brand products though 2010, the last I looked, mostly in the subcontracted garage developed boxes that either forget about all the things that can go wrong, or didn't care, lose a bit at a bad time it probably bricks a CPU. But we learned plenty of hard lessons in the 70s and 80s.. :)
Macan 4, Macan 4
Second Macan is in for windshield replacement today and will also get the software update. First Macan went in for software 2 weeks ago. No issues in two weeks on first vehicle. Dealer is likely one of the largest in the world, and is very competent.
On a section of road that recently was torn up and rerouted, I was getting Innodrive errors on the new section (likely due to a gps mapping database discrepancy). That went away, I think, before the software update. If I recall this correctly, then that would seem to imply minor OTA updates to roadway data. Perhaps we all can hope minor, frequently changing data could be updated OTA (roadway data, charging locations).
My updated WSJ0 without issue, everything seems to work including home charging. In response to my "reluctance to fix something not broken" comment, tech indicated this update should keep it not broken. There was no mention of updates other than a more robust network architecture.
One of the new features was listed as being able to open the charge ports from The App.
I assumed this was the phone app, but it appears to be the in-car charging app, which now has buttons to open and close the ports at the screen where you can set the charge limit. Useful if you lose the Exit screen when messing with a charger
Electric Macan EV 2026 Software Update via Dealer - What does it do exactly? IMG_7993
MatC21
I think maybe people are reading that in a way other than you intended.
What I assume you meant is that the older cars won’t get some of the features that MY ‘26 has via software.
Or are you really saying that you don’t think MY24 or 25 Macans will ever get another update, at all, period (“abandoned”)? I am not sure anyone could know that - not even Porsche would know if they might need to react to a security issue or recall.
I actually reached out to Porsche and received a reply.
They confirmed that MY24/MY25 will only be getting bugfixes and small improvements going forward. No major updates are planned.
Only MY26 receives the 'new' software with the improvements to the Charging Planner , Digital Key and other minor GUI improvements. This is because MY2026 is running on a new hardware generation (cluster) which makes backporting impossible (their words not mine).
They said it is in line with the industry standard - I guess they have never heard of Tesla or BMW.
Generally, I would not expect any Porsche to ever receive any features _after_ delivery, cause the same will repeat with the MY26 models when MY27 or MY28 is announced.
I don't think they understand modern car software - if you look for that in a Porsche, shop elsewhere.
Backporting is a common software term that probably only someone familiar with the nuts and bolts of development has heard.
It is actually a industry standard, as it can cost big money to backport. Not an easy business decision.
It is like moving from hardware that uses ARM processors to one that uses Intel processors. They redesigned the software to work on an Intel platform (i.e. port) along with adding features and for business reasons chose not to add the features to the old ARM software (i.e. backport). Very common.
Now if they were moving from ARM hardware to newer ARM hardware that was backward compatible it may be easier to backport.
I think VW/Porsche is moving from a less sustainable stovepipe modular architecture to a more sustainable flat architecture and we are caught in the middle.
