Annoying Auto Engagement of Hold Function When Entering Garage
NLSF
SF
24 Macan Turbo
Can anyone help guide on this? I have a narrow garage entrance and carefully and slowly enter and exit the garage. During this process, my turbo regularly engages the Hold function, resulting in a jerky and annoying process. Any setting/ adjustments or suggestions are much appreciated.
Thank you.
The hold function only comes on if the brake pressed very far down... And you have to be at a complete stop already...so I'm not sure how this is happening to you.
I too have to enter my garage slowly, alarms going off over and over... But I've never had it hold on me
Afaik, there's no options/settings for hold
NLSF
SF
24 Macan Turbo
It feels like a lurching jerking brake
CandianPorsche83
Vancouver
Porsche 911
Are you sure it’s not the safety feature that puts on the brake randomly when reversing? Think other members have mentioned it in other threads and my SA had advised me to turn off
Many cars have warning and auto braking features under the park assist menu item where you fine tune the alarms and response, like turn auto braking off..
I don't think you can silence them completely now days.
Frankie
Netherlands
Porsche Macan
My previous car, a BMW Z4, had this automatic parking brake function. When the car got too close to the wall when parking, the emergency brake would intervene to prevent a collision. I don't think the Macan has this function.
Thank you.
On the Taycan you can adjust the roll detection to be early, late or somewhere in between - this is the adjustment for Hold and when adjusted addresses your issue.
Search PCM for the setting - somewhere within Vehicle or Assitance (Warn Brake Assist)
O
That's not quite correct as it features also as part of roll detection and engages if roll is detected .
NLSF
SF
24 Macan Turbo
I will try this! Thank you.
there are no settings for the hold function...search the PCM for roll and hold...and all you find is the explanation from the manual regarding it's functions or interference on inclines.
so if NLSF's driveway entrance has a 5* or greater grade...this would explain everything
For the Taycan It's the Warn Brake Assist setting but the Macan doesn't appear to have that level of control - can't see it on the simulator and is either off or on rather than off, early, medium or late.
Tad annoying as I use the feature when entering my garage and prior to setting the car would hold just when you didn't want it.
I wish Porsche would standardise little useful things like that.
