Apple EV Route Planner & Plug & Charge
dieterf
Dieter
Chicago
2022 Porsche Macan GTS
Took delivery of my new Macan Electric Turbo and my expectations have been exceeded thus far. I do have two questions that I can't figure out how to solve and could use some help:
1. It appears Apple EV Route Planner is not compatible or enabled for the Macan Electric, or I just can't get it working. Anyone else having this issue?
2. Plug and Charge is grayed out within PCM and will not enable in the My Porsche app. Under Account/Charging Service in the app it also shows "Please activate Plug & Charge for your Porsche Charging Service contract." Any ideas?
Electric Macan EV Apple EV Route Planner & Plug & Charge Screenshot 2024-09-22 at 3.59.12 PM
Electric Macan EV Apple EV Route Planner & Plug & Charge IMG_87B6229C5A56-1
driege
Seattle, WA
Macan 4S (on order)
I don't know the answer to your question, but would you mind sharing a mini-review of the car so far? (perhaps in a different thread)
plug&charge is a contract service provided via your PorscheID like Porscheconnect - check for services in your porsche portal on the web or talk with your dealers - there is some service-side provisioning that needs to be done by Porsche - it's called the Porsche charging service - at least it was for Taycan and once you active your Porsche charging service and set it up you can use Plug&Charge…
dieterf
dieterf
Dieter
Chicago
Quick update: Spoke to Porsche Connected services and Apple EV Route Planning is coming to the Macan Electric in the future after a software update. It’s already provisioned on their end, so it’s only a matter of time.
Regarding the Plug and Charge, that is something the dealer needs to initiate to unblock it. I am still waiting for a solution and may have to go back to the dealer for them to reset it after it’s unblocked.
Senna
Leo
Austin, TX
Audi SQ7, Macan 4
Will those updates be available over the air, or will we need to bring the car to the dealer?
dieterf
dieterf
Dieter
Chicago
I was told over the air, but given the lack of knowledge since it’s so new, I am not sure I believe that.
dieterf
dieterf
Dieter
Chicago
Another update regarding the Plug and charge. The dealer has to initiate something to enable the service. Once completed you can request a certificate via the My Porsche App under functions/charging then click on the gear icon on the top right. Toggle the plug and charge and follow the prompts to request a certificate. If it’s spins and does nothing then the dealer did not activate it. A few minutes later the certificate can be installed after the request is accepted. Hope this helps.
Electric Macan EV Apple EV Route Planner & Plug & Charge IMG_0997
That would be really great, I use Apple Maps all the time and this integration would be really great, so I hope this is real!
DuckMan
NH
USA Macan 4. Our plug and charge did not authorize although we had a valid subscription. Turns out it is a know problem with malformed cert installed in car before we recieved it. It needs to be deleted by the dealer (possibly could be done by myself) and good cert re-installed. Will let folks know if that worked.
