Door closing issue
nulled
nulled
I’ll give it another try and keep you posted. However, the issue definitely seems to be caused by the window not lowering enough. When I lower it further or all the way down, it closes properly.
nulled
nulled
Tried few times but no luck... I'll be really grateful if someone can share how much their window drop when they unlatch the door so I can compare. I've booked a visit to Porsche for a check but I am just curious what it could be.
drjokic
Drazen
Croatia
Bmw x3, waiting for Macan 4
Hi nulled,
Did you mange to solve this problem? I have same issue, tried windows calibration without success
nulled
nulled
Hi nulled,
I'll be leaving the car for service tomorrow and let you know if they can fix it.
nulled
nulled
In case someone is following this thread:
I went for service today and the guys told me it's normal for a new car and it should get better with time. I think it's an air pressure issue because it closes fine if I leave a door or window open. All panels are well aligned so it's not a misaligned door, etc.
it's an air pressure thing...then if the windows lowered a lil more, so that there was a gap...it wouldnt happen.
but honestly, not seeing others with the same issue, makes me think something is wrong here.
I have the same idea… something wrong in my opinion since there are no other car with this kind of issue
drjokic
Drazen
Croatia
I am confused because I have problem only with front doors, back doors are fine. I will also make appointment to check
nulled
nulled
Will give it a month or two before complaining again ?
platypus
New York
'24 Macan Turbo Electric
Same issue on my side, the front doors require too much force to be closed properly, and half the time I have to re-close them. This is not ok, but I'm pretty sure the dealership is going to say they can't do anything ?
Dealer: “Please call 1-800-Porsche. ?”
nulled
nulled
Very annoying indeed. Do you have the same issue when you leave one door open? I think it's air pressure. I wonder if I am gonna mess up the hardware in the door from all the slamming...
