Final advice on final 4S build almost locked down PTKVFXK7
Adrian B
Adrian B
Macan E GTS delivery April 2026
Good plan.
Pretty sure it won't be much stiffer (people over assume too much) and if anything more compliant and just feel properly sorted.
Remember also the Ackerman Effect. Present on most Porsches, more pronounced on larger rims and yes will be annoying on 22" rims. If not familiar then this is what you experience when low speed manoeuvring in wet and cold conditions - tyre skipping.
Thanks for your help and advice
Adrian B
Adrian B
Good plan.
Interesting about the Ackerman effect as I’d never heard of it - now I understand what was happening on my Panamera on those 22ā€ on full lock at low speeds on a cold morning. I often wondered what the ā€œslippingā€ was. Didn’t bother too much and less so now I know what it is!! Thanks
I have a 4S but with only 20ā€ wheels - like you, I was looking towards the comfort end of the spectrum. It came with Bridgestones which I found really ā€˜hard’ as being more a performance tyre - I wasn’t buying the Macan purely for performance. I swapped to Pirelli Scorpion MS Allseasonā€˜s (mild UK winters). They made an appreciable difference to the ā€˜ride’ so I think the tyres may make as much difference as the wheel size.
I hope you enjoy your Macan as much as you hope to.
Adrian B
Adrian B
Good to know. Did you go for the extra Air Suspension option? Are the supplied tires runflats as know they don’t help? Had you tested a car with 22s to compare with the 20s? Thanks in advance
Yes I have air suspension. The Bridgestones are not run flats, allegedly they were designed for the Macan EV (?). No, I didn’t try the 22ā€ as I was quite happy with the look of the 20ā€, increased range and chance they would be more ā€˜comfortable’ than the 22ā€ (other may well disagree). You found the 911 a hard ride - any chance it had Bridgestones fitted ?
The major difference for me is the noise difference. The Pirelli’s are much quieter than the Bridgestones - I have acoustic glass.
It seems to me the Bridgestones are designed using a performance criteria whereas the Pirelli for a more quieter and comfortable ride - depending on what you want to use your SUV for.
MMR
For the 22ā€ Spyder wheels specifically (not sure if it translates across the others):
  • Pirelli
    → Generally scored best for noise / comfort
    → Softer compound + sidewall tuning = quieter ride, especially noticeable on coarse UK roads
  • Goodyear
    → Typically comes out best on rolling resistance
    → That translates to being more economical (slightly better EV efficiency)
    → A touch firmer, so not quite as hushed as the Pirellis
while I like the "look" of the sports design kit - I'm not a fan of the "chin/front splitter" it adds to the front of my 2024 Macan EV Turbo - this chin also lowers the clearance of various road-transition entrys w/dip and parking with stops/curbs…
if I had it to do over again I would check the following box…
Electric Macan EV Final advice on final 4S build almost locked down PTKVFXK7 IMG_0102
also having lived with a Macan 4 EV loaner w/22" wheel options and my 2024 Macan Turbo EV with 20" wheel options - I'm all in on the smaller wheels for better range and comfort…
My wife and I prefer the 14 way seats vs. the 18 way seats and we checked the massage options
I always prioritize "functional options" like RWS or Torque vectoring vs. "cosmetic options" like color of trim or various carbon fibre substitutions…
Personally love the driver assist no reason not to get it IMHO
there IFIFY :p
PTBN3US1
20" wheels for range and max-comfort
passenger display - cause it's better than staring at blank plastic-trim
"offroad" kit because the front splitter hits things in normal road driving parking lot situations
massage/vent options for the seat
driver assist
torque vectoring
but that's my car - not YOUR car
your build is just fine! but those are my considerations.
In UK 992s come with summer PZeros (standard on my 992 with Carrera Exclusive Design 20/21).
992s don't have much sound proofing and offer a more aural experience in general and highly road surface dependant. Acoustic glass won't help in this regard as much of the tyre roar rises through the footwells.
I personally think Michelin are better and last longer.
_THIS_ option is worth considering - but it comes with a whole bunch of unrelated changes…
Porsche does itself a "disservice" here using the words "terrain" and approach angle - all legit off road terms, and a correct description…
I've never had my 2024 Macan EV Turbo in any "terrian" - but I do drive normal streets, driveways, and curb entrances - my front splitter introduces itself to many of these normal and everyday items much more often that I like…the cars front splitter often scraps the ground if there is simply a medium or large "dip" in the road - hardly "offroad" conditions…
if I was to build a new Macan EV this design option would be part of that build - unfortunately it causes other cosmetic changes on the sides, fenders and rear of the vehicle that you may or may not want…
I'm not saying this a _MUST_ do, but I'm simply noting it so anyone building a Macan EV goes in "eyes open" - this is not just an "offroad" thing - it's a normal everyday front bumper cleareance thing…
Electric Macan EV Final advice on final 4S build almost locked down PTKVFXK7 IMG_0103
in my world the "more demanding terrain" is a parking lot entrance that has a huge dip as you transition from the road to the parking lot - or the gas station entrance in Capitola - also with a large dip where the front of the car "meets" the parking lot entrance - what is an EV doing goign to a gas station? Well it has my favorite "no touch" car wash so I can keep my Macan EV looking tip-top…
this is not just for "offroad" - it's for any undulation's you will encounter in the everyday world - or perhaps that curb at the front of the parking stall that is a bit taller than you'd like…
TS23
BMW G82 M4
My outbound M4 had pzero corsa’s and swapped them to pilot sport 4S’ and they were far superior in every sense. Interestingly they were star marked and were a completely different compound to other non star marked name sakes.
Wonder if Porsche went to the same extremes to build their own compounds etc?
Adrian B
Adrian B
Good to know thanks and interesting.
Adrian B
Adrian B
Thanks, it’s certainly a consideration but as you say causes issues as REALLY like how the kit improves the look at the back.
"eyes open" purchase is my goal - making an informed purchase decision - after that personal preference and trades off is the most important factor…I think we're clearly "in the zone" that you're making well informed choices
