Heated steering wheel too hot
castlg
Gary
Westhampton
2025 Macan EV 4S
The wheel gets unbearably hot when you switch it on, or when you pre heat the car. Any known fixes?
unbearably? ...
wow, the complaints have been that it doesn't get hot enough.
my wife's kia heated wheel is definitely better...more consistently hot.
I find the Macan wheel to just have hot spots....but hardly "unbearable" IMO
robrain
Rob
Whistler, BC, Canada
I’ll swap you with mine. It gets all the way up to ā€œmehā€ degrees.
More usefully, ask your dealer if you can compare with other cars on the lot and if it’s out of whack get them to take a look at it. I’m sure there’s a potentiometer somewhere (or digital equivalent)in the system that could be tweaked. I might ask my dealer the same next time I’m in.
dwauch
Santa Monica CA
2025 Macan EV
perhaps it is overheating. you should have the dealer check it out. they could probably test it somehow. Temperature might be out of range.
M324
Germany
Porsche Macan electric 4S
I am hearing for the first time that the steering wheel will be activated when pre heating the car?!
Has it been always the same or just started happening?
Going by the consensus, we all get it mildly heated.
Get it checked out soon, or next you might get smoke out of it :)
My Dec 2024 build std 4S steering wheel gets hot sometimes, some spots more than others until it fully warms up. If I'm not wearing gloves I have to turn it off. I've not looked for an adjustment as it seems to work like other cars I've driven over the years. There may be some variation with cabin or outside temperature, however.
FINMacan4
JJ
Finland
When the driver’s seat has been selected to be preheated as well, the steering wheel will also be pre-heated.
Electric Macan EV Heated steering wheel too hot IMG_0382
Doesn’t anyone read the manual šŸ˜„
