Macan EV won't select gear - Solved! (disconnecting the 12V battery)
Redleg
Robert
Australia
Vespa
The car worked flawlessly for the first two months but then wouldn't engage Drive or Reverse (only Park and Neutral). Charge at 80%, 12V at 14.6V and no warnings/error messages. No response to turning on/off, removing key etc. Called Porsche who wanted to tow it back to the dealer.
Problem solved by disconnecting the 12V battery by removing the negative terminal for 10 minutes. (Battery in frunk under plastic liftout panel). Engaged first go with no settings alterred. Must have reset the gear selector computer. Will now need to leave the appropriate-sized wrench in the Frunk in case it happens again away from home.
Electric Macan EV Macan EV won't select gear - Solved! (disconnecting the 12V battery) IMG_7056
Redleg
Robert
Australia
Vespa
5/8, not metric for some reason.
Negative terminal is on the right/Drivers (for US) side of the car. I believe it's accessible through the vent in the frunk. #2 in the diagram.
Electric Macan EV Macan EV won't select gear - Solved! (disconnecting the 12V battery) 1757507589734-5g
Mk42
Macan Turbo, BMW 225e xDrive
Hi, same thing happened to me on Christmas Day. I needed to drive to visit family, but the car was completely stuck in the garage, only park or neutral. I called and got the same unhelpful response from assistance: could have the car towed to a dealership but couldn’t commit to providing a loaner due to the holidays.
So after finding your post I disconnected the negative 12V battery cable. After reconnecting it, everything worked normally again. One thing to note: the alarm did trigger during the process - in hindsight, maybe should I have left a door open to avoid that.
I’ve now added a wrench to the frunk so I’m not stuck again if this happens away from home. Thanks for the tip, it worked perfectly.
skshimer
Skip
Southport, NC
Just curious. Did you try rebooting the car by depressing the volume knob on the center console for 30 seconds?
Do you 2 had the latest update installed?
Yesterday I was in a similar situation after I stopped on an incline to get my mail before moving on to the garage. It would not shift out of park, although there was some activity. It appears in that situation, the seatbelt must be fastened.
Mk42
I don't know. Car went in for service in Sept. where they did some software upgrades and fixed an issue with the rear axle wiring harness.
