Surprised by Tow Hitch
DuckMan
NH
I'll try tomorrow and see. Don't think so though.
ExVolt
Rick
Sf
Volt
Are you talking about the gap vertically between the license plate and the hitch?
If so, that has to do with the configurator showing an EU plate (skinnier but longer plates) vs the NA ones (taller and shorter).
Do you lose the foot release of the trunk when you spec your Macan EV with a tow hitch?
You do not lose the foot release when you spec the tow hook.
DuckMan
NH
You have to enable under the locking without key options. Not enabled by default. Foot raises and lowers it nicely.
Alex74
Alex
Taycan 4 CT, ;Macan Turbo EV (on order),
these are pictures from an EU car. Saw this one from my client.
MatC21
EU configurator says tow hitch actually costs 7km of range. Not that this really matters but could it be due to the worse aerodynamics due to the opening? Is that fully closed when no hitch is installed?
Colin the Best
italy
This is the tow bar hole on my Macan,....unbelievable; collects all the dirt, not to mention the possible turbulence and/or loss of efficiency over long distances,...is it possible that Porsche hasn't thought of a plug, perhaps one that can be inspected, but to close this enormous hole?....on a car 140K seems like the minimum to me..
Macan EV to be delivered… or not
I totally agree, in the meantime I don’t think airflow and so as dirt will go into that cavity.
it’s just amazing to deliver cars with hole which is not needed to do something …
MatC21
Do you have this hole even if no hitch is installed?
Colin the Best
italy
@MatC21 Yes I do,….; no hitch installed, but a great hole for no reason
Can someone 3D print a part that you click in place? Even when having a tow hitch it would be nice to cover this up …
