Surprised by Tow Hitch Cutout
ExVolt
Rick
Sf
Are you talking about the gap vertically between the license plate and the hitch?
If so, that has to do with the configurator showing an EU plate (skinnier but longer plates) vs the NA ones (taller and shorter).
Do you lose the foot release of the trunk when you spec your Macan EV with a tow hitch?
You do not lose the foot release when you spec the tow hook.
DuckMan
NH
You have to enable under the locking without key options. Not enabled by default. Foot raises and lowers it nicely.
MatC21
EU configurator says tow hitch actually costs 7km of range. Not that this really matters but could it be due to the worse aerodynamics due to the opening? Is that fully closed when no hitch is installed?
Colin the Best
Mark
italy
This is the tow bar hole on my Macan,....unbelievable; collects all the dirt, not to mention the possible turbulence and/or loss of efficiency over long distances,...is it possible that Porsche hasn't thought of a plug, perhaps one that can be inspected, but to close this enormous hole?....on a car 140K seems like the minimum to me..
I totally agree, in the meantime I don’t think airflow and so as dirt will go into that cavity.
it’s just amazing to deliver cars with hole which is not needed to do something …
MatC21
Do you have this hole even if no hitch is installed?
Colin the Best
Mark
italy
@MatC21 Yes I do,….; no hitch installed, but a great hole for no reason
Can someone 3D print a part that you click in place? Even when having a tow hitch it would be nice to cover this up …
pbar
Paul
Macan 4 EV, 992 GTS
No - mine works fine. I also think the 'hole' is ugly and not something I expect on a $100K vehicle.
I also wish there was a way to disable the rear parking sensors when I have a bike rack on the hitch. :-(
bennksy
SF Bay Area
Macan Turbo, Model X
Great news that the newer cars seem to have the metal piece painted or cover. I had to re-spec my build when i saw the the metal part was clearly visible even at a distance.
masmole
It appears that they have made improvements on newer cars. At minimum all the internal pieces that were silver have been painted black.
Anyone else here who has taken delivery of a recent build of a US-spec car with tow package confirm such changes were made with regards this black-painted bar behind the tow hitch?
I suppose if I add it to my build and it's not black, I can always just paint it myself.
