CHP
Christian
London UK
ex Macan 4S's
but is it necessary to misuse every thread for this? this thread is about the features of next years model.
I haven't looked at the thread header at all, and yes, this certainly does not belong here. I simply replied to messages, one was yours :cool:
MMR
My SA seems to believe that there will be a new Sports Design Package for the MY26 Macan, but I’m not seeing that mentioned anywhere else…
It turned up on the GTS, so he was ahead of the curve!
mine has been also a reply, fact is that no matter what the real topic is always the same three people (one of them admittedly do not even own an macan) state some outlandish grievances about the macan.
Yep the new package is in the configurator now. Transforms you sub GTS spec into a GTS.
Reactions: MMR
MMR
Credit to the guy, he mentioned it before the MY26 models were announced - I assumed he was wrong when it didn’t show on the MY26 configurator - until a month later when they released the GTS…I may have waited had I believed it was imminent at the time!
Yeah, I just played with the configurator bit and compared a fully optioned Macon 4 and a GTS and the difference turns out to be about 7K more for the GTS (Canadian funds). This is because many of the costly upgrades to bring a Macan 4 up to GTS spec are included as free or much lower cost in the GTS plus in the GTS you get torque vectoring and improved thermal mgmt and track mode suspension settings not available on the Macan 4. INTERESTINGLY, a Macan 4S is more expensive than a GTS when you go deeper into the option vortex of no return 😬
Reactions: MMR
MMR
Agreed - it’s wild!
They practically give the sports design kit away with the GTS! (compared to the cost with the other trims)
Agreed - it’s wild!
Also learned that you cannot get 20 inch rims on the GTS by ordering on the configurator or any other way. Porsche came back and said they are not approved and they don’t really say why. This is strange because you can get them for the turbo. I suspect it’s because of the special GTS lower suspension setting..
MatC21
Could also have to do with the fact that the 21 inch come with wider tires. And they really want you to put on these wider tires considering GTS is the 'driver focused' car.
If you want more comfort or range just take a 4S, GTS are always specced rather 'aggressively'.
