What's your estimated range with 100% SoC?
FirstEV
Sweden
That is pretty nuts for that condition I do not even get that in mild weather on 20 inch … of course it’s a Turbo, but driven normally I would not expect it to be so far off, seems the bigger engine is more hungry. Curious what the new software will do, hopefully I’ll get it installed when I enter it for recalls later this month …
Maybe it is a bit easier to be a bit hard footed on the gas when driving a Turbo ;)
Jokes a side, hopefully the update might do some adjustments for efficiency! :) I also have RWS, which I assume you have as well so it is a pretty good comparison!
If Porsche would bring out a rear only powered GTS I would get in line, 110kwh battery flatter charging curve (do not need to be 400kw) they would have a hit on their hands, ultimate range, fast charging and fun factor 💯
We recently moved the company into a new office, and now I go 45 mph instead of 75 mph to and from work. I noticed the guess-o-meter has significantly increased -- 263 miles on 80%, so 329 miles at full charge. I guess those "air drag and rolling resistance increases by square of velocity" formulas really do work ...
The cold seems to be having a bigger effect on our Macan than it does our Mach-E. Drove home to CO from Jackpot NV yesterday. Morning temps were 25F-35F (cold but not frigid). First leg was intended to be 211 miles from Jackpot to Perry UT (EA station). Charged to 100% at the hotel, so I figured it would handle that with at least 15% to spare. Nope. I was only getting 2.0-2.3 MPK, and the nav was saying I'd arrive at 0%. So I stopped and added 10% at the Heyburn ID EA along the way. Even with that, nav was gradually dropping from 10% to 7% arrival, so I backed off the speed and turned off the climate for a while until it became clear we could make it.
Ended up arriving at 15%, which means it took 95% to go the 211 miles. That's 222 miles of range. Mix of 2-lane highways and interstates. Speeds between 70-80 MPH. Net 900' elevation drop.
Got somewhat better the rest of the drive home as temps warmed to the mid-40s.
Similar to our Mach-E, dropping below 40F seems to be the point where range loss gets serious. But 30% loss (vs EPA) was more than I expected at temps around 30F. We usually don't see that much loss in the Mach-E until we get below 20F.
It’s not 30% loss vs EPA in cold temps. It is 30% loss in cold temps and 20mph above EPA tested speeds. I have no doubt I can get nearly 300 miles in my Macan if I stick to 55mph.
highway 150kmh cruise control
range: 400km
range: 400km
I have a Turbo on 20 inch wheels and never ever can I get that range at 150 … 120 - 125 maybe. That was on the Potenza’s
I have the new Hankook tires since yesterday, consumption seems lower so maybe that 400 is in reach if it is 22C and no head wind …
150kmh is cruise control setting. the reality is less of course (also our speed limit is 130..) and my tachometer is 5 km off. but I have 22 wheels
It's a great result, for those observing less keep in mind it's not only tires but also the road - different highways have different compounds and friction differs.
Did 211km on the new tires trip 4/5 target speed 125km/h (rest backroads) consumed 53% giving a real range of 390 at 15C with slight cross wind. Consumption averaged around 20.5kwh / 100km which indicates a 450km range at 94 kWh battery which is the projected range … there always seems to be for me around a 10 to 15% discrepancy between actual and projected, hence they call it a GOM, but it could be more accurate …
To soon to tell but the new approved Hankook tires seem more efficient, hope they will last longer than the Potenza’s (15k km)
Fluff
I can go to work either cross country, slow road, 30-50mph, or motorway, 70+ all the way. Difference is then 250 miles range on motorway, or 300 on the back roads. Back roads is only 30 miles, motorway 50 miles, takes the same time.
McgR
Taycan CT 4
You can avoid this by not charging to a 100% and when you start pre conditioning manually before departure you up the charge target to 100% … of course you need to have 11kw charging, otherwise this will not work.
I used to have a Taycan CT 4 forst gen it was impossoble to visit my parents without charging. Total 420 km. From your experience would this be possible with a Macan Turbo. What wheels do you have ?
That would depend on what average speed you would drive and in colder/winter that would be a challenge … I can do Antwerp / Amsterdam and back without a charge that is 360km and have around 20% to spare in summer … but winter that would be a challenge … so I guess you would need like a 5 minute stop
I have the 20 inch wheels especially for range and now the most efficient Hankook’s that seem to edge out some extra km’s. I drive normal, like 7 over the limit …
McgR
Taycan CT 4
How is the comfort with the 20 inch wheels ? Do you have a lot of road noise? How does is handle the Belgian steenwegen and kasseien ?
