What's your estimated range with 100% SoC?
McgR
Taycan CT 4
That would depend on what average speed you would drive and in colder/winter that would be a challenge … I can do Antwerp / Amsterdam and back without a charge that is 360km and have around 20% to spare in summer … but winter that would be a challenge … so I guess you would need like a 5 minute stop
I have the 20 inch wheels especially for range and now the most efficient Hankook’s that seem to edge out some extra km’s. I drive normal, like 7 over the limit …
Thx! I know about the difference in range for speed and temperatures. From Antwerp to Breda with the speed controle I put CC on 126 kmh and in NL I usually drive 106 surfing daytime but 136 kmh when returning home after 19h.
For range and comfort I would condor the 20 inch tires. It would be nice of it was possible to do the trip without charging when driving normally.
How is the comfort with the 20 inch wheels ? Do you have a lot of road noise? How does is handle the Belgian steenwegen and kasseien ?
Road noise is OK, handling is really good, I have the Air suspension, I would rate it good, but it is more on the sport side …
Range is going up these days
Electric Macan EV What's your estimated range with 100% SoC? 1777299485972-kd
Electric Macan EV What's your estimated range with 100% SoC? 1777299433718-9o
McgR
Taycan CT 4
If this is with normal speeds on the highway it would be sufficient. Currenlty driving a RR Sport PHEV. Wich is very comfortable and silent. I was hoping the Macan would be in the middle between the Taycan and the RRS. Will have to make a test drive. I had a lot of tire noise with the Taycan on 20 inch wheels. And it was difficult getting in and out.
As indicated normal speeds, and little sporty, but I do anticipate … so that helps, this is probably with AC off as I have roof that opens … but AC does not take much, about 30km’s so at 100% and some losses 400 is attainable when charged to 100%. It will not be as quit as the RR but I did not take the double glazing…. I want that people can save me when in a bad car crash ;-)
Daniel
Europe
Sold:Taycan 4, Now Macan 4
I traded in my 20-inch CT4 for a 21-inch Macan 4 16 months ago, and I'm very happy with the change. There's no improvement in noise; the wheels remain the main source of noise, especially on rough surfaces like icy roads.
I don't think double glazing is very effective for that.
Of course, it's much easier to get in and out...
Today range: 333 km for 56% battery
Fly4ever
That's really impressive...!!!Almost 600Km on a 100% charge!!At what avg speed you get such a range? Just city driving and B roads or motorways as well?
Daniel
Europe
Dont forget it is only a guess-o-meter !!
B roads south French Alps,90 km/h limited , no motorway , a bit of city driving, air conditioning only 10% of the time, allmost allways lowest setting.
Today "Since Charging" : 150km,44 km/H, 15.0 kwh/100 km.
Since october 2024 (including 2 complete winters periods) : 16575 km , avg speed 48 km/h, 17.5 kwh/100 km
10-15% below EPA is still about the max I'm seeing at 70-75 MPH. Had another 265 mile leg to try and do yesterday (my EPA is 315). There's a bailout halfway through to detour another direction if needed (longer route but there's a charger 50 miles closer that way). When I got to the decision point, the Porsche nav said I'd make it with 2%. That's too risky so I bailed out.
2.8 MPK is about as good as I get on a long drive. 2.8 x 95 kWh = 266. Sounds about right.
MMR
Now the weathers improved and I’m mainly doing urban driving it shows just over 350miles for 100% charge on my MY26 Turbo.
When I picked it up in December it used to show 260.
EPA isn't all driving at 70-75 MPH, it's a mix of driving conditions and speeds. You will never achieve the EPA range estimate at that speed -- neither would an ICE vehicle.
Correct. EPA range is a relatively low speed measure. But it is the number we have to work with because they suck as giving us a better, more meaningful measure.
Thus why I noted it as the baseline to measure against.
Reactions: MMR
Just fully charged to 100% and it gives me 569 km with a little over 91kwh in the battery my cell imbalance went from 2.2 mV to 3.4mV … if that evens out in an hour or so I’ll try to add that 1 kWh it claims it should be able to contain car scanner claims the max capacity is a little over 92 kWh and states the charge level is at 98.5% or so in regards to what it could hold…
Curious if I can add some more. The claimed range is in the neighborhood of the WLTP 589km ….
After a little over an hour the imbalance dropped from 3.4 to 3.1 but as it is still displaying 100% on the dash, charging will not resume. Car scanner claims tha charge has dropped from 98.25% to 98.1% ….. Need some more patience I guess …
Electric Macan EV What's your estimated range with 100% SoC? IMG_0366
Electric Macan EV What's your estimated range with 100% SoC? IMG_0365
ADS
Alexander
Berkshires, MA
Macan 4 EV
Are you going up and down a lot of hills? I see Colorado, so... I do see that hills reduced my range noticeably.
Some but I adjust for that. The ups and downs mostly cancel each other out. What matters is net elevation gain/lost from start to end of the leg. If I go up a few thousand feet then down the same amount within the same leg, it makes very little difference compared to if the the road were flat the whole way.
We actually tend to get better mileage/range on mountain legs, but for a different reason -- the average speeds are slower. Pretty big difference averaging 70 MPH vs 80 MPH.
