- First Name
- Diego
- May 12, 2024
- Italy
- Macan 4
If it would be helpful, I would like to collect in this discussion records of problems described by users up to the date given in the title:
Please consider this thread as a glossary thread, which links to individual reported issue threads (where everyone can reply and comment). If you have an issue, please create a new discussion thread for it and it will be added to this list.
Area / thread link | Issue | Region | User | Cause | Fix |
Air Conditioning | no cooling is provided. | US​ | @n4v4nod​ | No freon installed​ | |
Air Conditiong / vents | passenger side floor vent / flapper doesn't close | US​ | @macanchan​ | TBD​ | Loose connection fixed, solved |
Climate Control Button | button intermittently don't work when the car is powered ON | US​ | @macanchan​ | TBD​ | Auto-reset​ |
Satellite Radio | connection lost | US​ | @macanchan​ | TBD​ | Not a recurring issue. |
Electric charger port cover | passenger port works randomly | US​ | @n4v4nod​ | Sensor out of position​ | |
Owner's Manual in PCM | No Contents are available in PCM | US​ | @dieterf​ | TBD​ | |
Instrument Cluster | instrument cluster does not turn on (display blank / dark) | Canada​ | @dmd​ | TBD​ | Auto-reset​ |
Blind Spot Monitoring | Blind Spot Monitoring not working | US​ | @adrnlyn​ | TBD​ | |
Assistance Systems Error - Speed Limit Display (Warning Message) | Intermittent fault messages displayed on instrument cluster | UK​ | TBD​ | ||
Assistance Systems Error - Speed Limit Display (Warning Message) | Adaptive cruise went out | US​ | @adrnlyn​ | TBD​ | |
Loud buzzing sound from mirror area | After triggering the front collision warning system there's a loud buzzing sound coming from the upper mirror area (cameras/sensors just below the mirror) getting worse pressing the plastic cover | EU​ | @TomekGnomek​ | TBD​ | Car restart solved |
Front (air) suspension cracking | Cracking sound from front (air) suspension when driving slowly over speed bumps | EU​ | @TomekGnomek​ | TBD​ | |
DC Charging Issue Due to Software Glitch | DC charge at an Electrify America terminal - no success. | US​ | @SteveY​ | software glitch | |
Bose sound stopped working | Only two front speakers works no matter what I do, reset pcm | EU​ | @Wawando​ | TBD​ | |
Compass intermittent function | sometimes compass works properly and sometimes it does not | US​ | @dieterf | TBD​ | |
Trunk emergency release error | Vehicle sounded alarm and displayed warning message while parked in garage | Canada | @shawn | Unknown | Alarm stopped on its own after 10 minutes and trunk operation is normal |
Smoke and burning smell from air vents | Burning smell and smoke from air vents when driving 130 km/h (80 mph) or higher, with or without the climate control on | EU​ | @piter95 | TBD​ | |
Rotating Random Sensor Alerts | Series of rotating random alerts that keep cycling | US​ | @GaryV | TBD​ | |
Charge Port | Charge port doors can open on their own in automated car washes | US/CAN​ | @daveo4EV | TBD​ | |
Charge rate | It appears North American Macan's are capped at 40 amp charge rate and not the 11 kW (48 amps). | US​ | @daveo4EV | TBD​ | |
Plug & Charge | "Plug & Charge" toggle that won't work. Unable to P&C and P&C option is grayed out on PCM and APP | World​ | Many | TBD​ | Solved by @TomekGnomek . See instructions here |
