Joder
Texas
Cayenne S, Macan EV Turbo
So I was looking at locations for where I'm going to put everything (dash cam, toll tag, radar detector) and it looks like the dot matrix is flat despite being quite prevalant.
I'm a bit worried about sticking anything adhesive to the dot matrix. It almost seems like it is inside the glass. Not sure if anyone else has experience with this?
macanchan
Allan
Do not put it on the dot matrix. Here's a photo of the heated windshield, see the film is hash cut? you can place it over that hash mark for reception. If you have the standard glass, you can place the transponder/radar detector anywhere else.
Electric Macan EV Dashcam installation issues -- fuse box location? IMG_2087.JPG
macanchan
Allan
Never going to happen… would be great, but about 0.0000001% chance of this happening. And I’m rounding up.
They know their cameras suck so they would never do this... lol
Joder
Texas
For asthetic reasons I would like to put the toll stick where my radar suction cup is right now in the photo. My only worry is that it will pull the dots away if I ever remove it. Then again the dots really seem pretty flat.
Electric Macan EV Dashcam installation issues -- fuse box location? PXL_20241016_180335850
macanchan
Allan
i guess you could try putting the toll transponder on scotch tape, trim, and stick it over the dot matrix.
I’m confused: is this a thing, pulling the black matrix area out of the windshield when removing a device? Has this happened with Porsche (or other cars) and that’s why you’re apprehensive?
I’ve always put my transponders there (with the double sided tape that comes with the transponders), always removed it without any damage, this across different car makes.
Never heard of this concern so genuinely curious about this.
Joder
Texas
Yeah don't ask me why I'm worried about it now. The Texas tag is a flat stick the size of a credit card with really strong adhesive. Just worried if I ever have to tear it off and replace that it might take some of the black with it and look bad.
Joder
Texas
Found the back fuse box. Looks like they are all active, however, I was testing with doors/tailgate open so perhaps they don't switch until these are closed? I have yet to find a switched fuse. I'll keep looking when I have more time.
I haven't found the fuse for the 12vdc outlets. That is certainly switched off.
Also found these two connectors. Wondering if they are for the pre-wire for the front/rear dash cams.
Edit: also found the fix a flat and tire pump.
Electric Macan EV Dashcam installation issues -- fuse box location? PXL_20241018_212727943
Electric Macan EV Dashcam installation issues -- fuse box location? PXL_20241018_212747878
Electric Macan EV Dashcam installation issues -- fuse box location? PXL_20241018_214107079
Electric Macan EV Dashcam installation issues -- fuse box location? PXL_20241018_212848659
platypus
New York
'24 Macan Turbo Electric
My installer did run into the same issue (only found active wires), and called me to ask if I had paid for the pre-wiring of the OEM dashcam (I haven’t). He eventually found the accessory power, but he didn’t tell me how he did it.
He did say that testing took a long time because the car continued to have power for 30 min after it was turned off.
Joder
Texas
Any chance you can reach out to them to find out which accessory power is switched?
stevieg
Steve
Hey,
Anyone know if the OBD port is on the drivers side or passenger side? And is it the side where the majority of fuses are located?
Finally, I think I need to connect to a permanent live which isnt switched, like the interior lights etc. Any idea what fuse that is??
Just wish this info was in a manual somewhere!
alvaro
Álvaro
ATL, GA Metro - USA
Tesla and rivian are able to use the built in cams as "dash cams" ... that would really be nice... hopefully an update can enable?
BMW as well.
