12v Battery capacity and charge type?
BigApple
Andreas
NJ
Macan Turbo EV, E-tron, M3
Getting a 3ch dascam that has a higher draw then a normal 1ch.
to make sure I don’t drain my 12v battery during overnight parking as I hardwire it to the constant 12v. Does anyone know the capacity on the Macan ev turbo and how it is charged. Some ev’s Trickle charge the 12 v battery. Some only during driving. Some only during charging of the car. planning on adding a dashcam battery also but this may just lower the draw for a few hours. trying to avoid a big surprise on A 1-2 day of not driving and being in park mode.
i can't see any info online...so you may be best just lookin in the frunk to see
BigApple
BigApple
Andreas
NJ
I just spoke to a Porsche ambassador at a dealership. He told me the battery gets charged by an attenuator. And that is of course not the best thing for my scenario. The battery only charges based on the amount you drive. He also told me the battery is under the passengers footrest. It is strange that some of the fuse boxes are then located in the back. Unless some of the info is incorrect. The car is so new that most of all we do is a first for everyone else also.
Update: Car gets charged when engine is on. And battery is in the Frunk. Dealership clearly did not know
This might be technically accurate, but is not useful. From the image in the manual, you can see where the battery is accessible from the frunk - the + connection is directly on the battery. It looks like you need to remove the whole frunk lining to get full access to the battery.
Electric Macan EV 12v Battery capacity and charge type? battery-location
BigApple
BigApple
Andreas
NJ
Hmm he told me that the pins are just pins in the frunk. It not the actual battery.
raass
Looks like the battery is on the passenger side under the lining.
Electric Macan EV 12v Battery capacity and charge type? IMG_8211
Interestingly in RHD drive cars the battery appears to be shifted over to stay on the passenger side.
Electric Macan EV 12v Battery capacity and charge type? rhd-frunk
BigApple
BigApple
Andreas
NJ
Today I went to Audi and was told that the ppe platform structure charges the 12v battery also as the car is being charged. I wonder what is now true. What actually charges the 12v battery.
TurboSpain
Spain
What they told you at Audi can be verified. Just use a multimeter between the poles of the 12V battery. It should measure between about 14V when you charge the vehicle and about 12.5 at rest.
BigApple
BigApple
Andreas
NJ
That makes sense. I will test that shortly. Thank you.
it's absolutely insane...but you have to remove the whole frunk, the tray, and crossbar to access the battery
I had to do the same with my Tesla model X
i've been trying to access the battery for the amp i'm installing...and i've just noticed that the battery is actually a 24v battery...it's not even 12v
Edit: my bad...i just don't know how to use the multimeter i had. too many option
