- First Name
- shawn
- Jan 11, 2024
- Canada
- Macan 4, Model Y, Model 3, XC 40 Recharge, Leaf
At speed you have wind and increase power so if is not wind then some component is burning off some lubricant (like a fan motor coil). Otherwise you have an electrical component burning out for some reason. I would have a chat with your service agent. If they said it is normal then they should have an explanation. I bet given these cars are new some excees lubricants was applied during production and is burning off. If the smoke and smell dies down then that is the reason. I could tell if I could smell it and so could your service agent. But again I would insist they do that especially if it is same or worse each time or even starts happening at lower speeds. Hope this helps
