Weird Smoke and Burning Smell from Air Vents in My Macan 4 – Anyone Else?
At speed you have wind and increase power so if is not wind then some component is burning off some lubricant (like a fan motor coil). Otherwise you have an electrical component burning out for some reason. I would have a chat with your service agent. If they said it is normal then they should have an explanation. I bet given these cars are new some excees lubricants was applied during production and is burning off. If the smoke and smell dies down then that is the reason. I could tell if I could smell it and so could your service agent. But again I would insist they do that especially if it is same or worse each time or even starts happening at lower speeds. Hope this helps
piter95
Pietro
Czech Republic 🇨🇿 (from Italy 🇮🇹)
Macan 4 (EV)
I will definitely wait for some of their answers. I don't accept anymore "it's normal", "nothing found" etc. If this will happen again I will go to a different dealership and if the different dealership will find an issue, I will sue the dealership from where I purchased the car.
Main thing is you wanna rule out the possibility of an electrical fire by some component. The only thing I can think of from the same dealer is if they pressure washed where they should not have and pushed water into the wrong place.
piter95
Pietro
Macan 4 (EV)
I have honestly no clue... All of these are great guesses... I think there are some electric components that are not properly working... Now and then I get the message that Safety system are malfunctioning. See pic below:
Electric Macan EV Weird Smoke and Burning Smell from Air Vents in My Macan 4 – Anyone Else? 349A003E-15A4-4EDF-A652-D77B871E9365.JPG
Assistance systems usually limit themselves if water or dirt is on a camera or visibility is bad.
piter95
Pietro
Macan 4 (EV)
Could be... I was driving on highway and it happens when I came back home, so maybe insects and dirt... But after shutting down and turning on everything was fine
Yeah moisture or fog build up can throw the error. It evaporates and reset should not be necessary but can speed up getting it back to normal
