Reminder re frunk / hood / bonnet opening when washing car: high pressure water may open it
I don't think I'm the first person to mention this (I didn't find it in a quick search but I'm sure I read it somewhere), but, since this just happened to me, I thought I'd remind folks:
Be careful when washing the car! High-pressure spray can pop your frunk if you have that feature, and since it opens on its own once released, that might not be fun.
I know there's a setting somewhere to disable that, but it's buried and you have to remember. In my case, I was just hand-spraying the car and I knew what was up as soon as I heard the click and avoided water penetration, but not everyone will be so lucky.
This car really needs to have an easily accessible car wash mode.
Disable comfort opening on driver key fob - press lock and unlock simultaneously on the key fob to disable.
All comfort features will be temporarily disabled until the drivers key fob button (any) is pressed.
meerec
Sydney
Lock the car and keep the keys inside the house or far away. Or place in a faraday pouch while being washed.
exactly right — I don’t know really what the issue is, just keep your key away from the car while washing, my Macan GTS and all other cars I owned in the past does the same thing.
henrus
Henry
Bay Area
Tip of the month!
AEY
Brussels
Can this also happen in a car wash tunnel when sitting behind the wheel on "N" gear ?
You appear to be making the not-necessarily-valid assumption that the car is being washed somewhere that keeping the key away is convenient. Plus one needs to remember--hence, "reminder."
I don't recall any portal in my Macan GTS that would pop open like the EV frunk does.
The useful key fob two button suggestion wins the prize.
did you really try this tip to disable the comfort access? I mean , in a Macan EV…
I’ve tried weeks ago, and it didn’t do anything…
is there any mention of that in the manual?
sarinotropeano
Sarino
New Jersey
2024 Macan 4 EV
And while they are at it there should be a way to lift the windshield wipers off the glass. Mine cannot be lifted without scratching the edge of the hood. My previous car had the option to shift the wipers for just such a need. Luckily, I don't need to park outside in icy weather where I would want to have them off the windshield to prevent them from freezing on it.
sarinotropeano
Sarino
New Jersey
2024 Macan 4 EV
It can be disabled in the settings. You must disable the setting that allows for the rear trunk access with the foot swipe and the automatic door unlocking when you approach the car.
LivingTheDream
Thomas
Greater Boston
Macan 4S 718 Boxster
There is. From the owners manual…
Replacing windshield wiper blades on the windshield
Extend wiper
  • Operational readiness switched off
  1. Press the wiper lever down once (position 4).
    The windshield wipers move upward through approx. 45°.
  2. Change the windshield wiper blades according to the separate manufacturer's installation instructions. Pay attention to the differing lengths of the windshield wipers!
Retract wiper
  • Operational readiness established
  1. Press the wiper lever down for approx. one second (position 4).
    The windshield wipers return to their initial position.
There is a maintenance mode for the wipers as per all Porsches.
Power on the car, power off press the wiper stalk downwards as if to flick wipe and the wipers will go and stop in the vertical position so that you can lift the blades.
Make sure that the driver's door is closed whilst setting.
Fadz
Ferdinand
San Diego, CA
Thanks! Any other factual and intelligent comment is welcome :)
Try this:
Settings, Vehicle Settings, Vehicle Locking Systems. Under comfort access, disable the Unlocking the Vehicle without using the vehicle key. Now go to the front of the vehicle with your key fob, and try sweeping motion by the Porsche Logo, left to right, and down motion. My 4 does not open the frunk no matter what sweeping motion I do. Note: After car wash, you may enable back to auto lock/unlock.
