Driver Door will not unlock / open
sooo i went to charge to at my local EA. I got out, and left my family in the car (it's super cold) while i got things going. I guess while i was standing beside and walking around the back of the car, maybe it thought i was gone...idk... but either way, while i was waiting for the charge to initiate (which for some reason took a while), the alarm went off...
no biggie, i just unlocked the car with the key... the charge eventually started and we went off to shop while we waited...
I came back at the end of the charge...and my Driver side door would not open. I unlocked it multiple times...you hear the clicking... back door would open... Front door would not open.
i climbed in the passenger side and opened the handle from the inside...
after that...went home and tried to mess around with the HomeLink stuff (unsuccessfully) and i was in and out the car a lot... but i never locked it...
my settings are set so that the cars locks when i "walk away" so that happens in the garage...the car locked.
i went to the store later that day, and got in the car no problem......
But when i was leaving the store, again...the driver's side door would NOT open! I had to go through the passenger side again...
anyone else have this issue?
this may actually make me have to take the car in if this keeps happening
The lock has electronic and mechanical opening phases. I suspect the electronic portion is not working properly or broken. Usually, the electronic opening is initiated when pulling on the inside door lever lightly but then if you pull more, mechanical opener is initiated required by law.
There lock has electronic and mechanical opening phases. I suspect the electronic portion is not working properly of broken. Usually, the electronic opening is initiated when pulling on the inside door lever lightly but then if you pull more, mechanical opener is initiated required by law.
yeah, just odd that it's intermittent...
Re Homelink - typically the issue is if your door opener uses a rolling code for opening / closing - it won't be compatible with Homeline and you may need to use a non-rolling code opener OR invest in a Universal Receiver (which doesn't use a rolling code and Homelink supports 100%) and attach to your existing opener.
Bohunk
Mark
2025 Macan 4S
I have not yet been able to get Homelink in my new 4S to control my door opener. The door opener is a Genie that uses rolling codes. Homelink in my Kia Sorento has always controlled it without incident, so Homelink does handle rolling codes. Did Porsche screw this up?
Not on the Taycan or Macan if your rolling code is proprietary. I use Horman for openers which have their own Blusecur rolling code and is not.
Perhaps Genie is similar?
Porsche haven't screwed anything up as this is an oem product.
My only gripe is that the system has been moved from the PCM and placed in the mirror once again.
Bohunk
Mark
2025 Macan 4S
After more attempts I was finally.able to get my 4S to correctly interact with my rolling codes Genie Garage door openers. It was just being finicky. I followed the directions in the manual and on the PCM several times and it finally worked. Patience needed.
Fleming23
Eric
US (Georgia)
Did the door lock issue look something like this?? My rear driver door does this randomly, and it is incredibly annoying. I have a service visit scheduled but still a few weeks out.
Seems rather dangerous to me, imagine in an emergency scenario and you can’t open the door.
nerv
Huy
BMW M3
Thank you for recording and posting. Very helpful.
Basically yes. But I didn't immediately try closing and opening the door again.
damn. it did it again today!
and I was in out of the car like 5 times before...then all of a sudden, the door wont open...had to oprn from inside again
AlanH
Alan
Marseille
Macan 4, Fiat 500e
I had the issue of the rear door not unlocking- the dealer replaced the lock and it seems to work fine. I’m located in France
Fleming23
Eric
US (Georgia)
It is so random when mine would decide to do it. Car is at the dealer now to get looked at. Of course it would not replicate the issue for them, but thankfully I had the video. I told them I did not want it back until/unless this was resolved.
