Closing trunk by your foot
AKomarek
Alex
Czech Rep
Hi, I can't find a way to close the rear boot with my foot on my Macan4. The manual says it should be possible, but I can't get it to work. Can you please share your experience? Many thanks.
I have the "Porsche Entry" included of course.
The manual isn’t really clear but I think it should close using the foot gesture.
Electric Macan EV Closing trunk by your foot IMG_1040
AKomarek
AKomarek
Alex
Czech Rep
Thanks for your opinion guys! However it would be good to hear from someone who has ever managed to close the trunk by foot.
LivingTheDream
Thomas
Greater Boston
Macan 4S 718 Boxster
If you removed all the factually challenged opinions from this forum, it would float away due to lack of mass!
That said, I tried it and it worked. One kick-like motion, just to the right of center did the trick. I thus stand corrected and retract my baseless opinion.
I hope you get it working.
You swipe to the right to close it. Left opens, right closes. At least that's what works for me, I'll have to test more to see if that's real. It does close it, I just did it
I didn't even know you could close it that way too. Never tried
CraigW1
Los Angeles
2019 Porsche 911 GTS, 2024 Macan 4
" You need to step away from the trunk (or not be too close to start with). If the car senses you standing right behind the car it won’t close as a safety precaution."
This!!! Took me a few days to figure out why it was only working intermittently.
AKomarek
AKomarek
Alex
Czech Rep
Thank you all! I will give it one more try today! Let’s see.
Check that the option is enabled - Vehicle Locking - Comfort opening tailgate option
Make sure the keys are on your person, centre of the bumper (not too close) foot in / out and step back, repeat to close.
Electric Macan EV Closing trunk by your foot 1737723124124-nz
It works to close it. As discussed in the video above, a kick, offset under the right side, triggers both opening and closing. There is just a bit of delay that often cause me to think the kick didn’t work, but if I wait a second, it usually opens/closes.
