- First Name
- shawn
- Jan 11, 2024
- Canada
- Macan 4, Model Y, Model 3, XC 40 Recharge, Leaf
If the original issue was no refrigerant then you have a slow leak and it was not likely that the factory just forgot to do it. This makes more sense because production checklists would not deviate on a procedure like that. If pressure is not exactly what it should be it will not work. I recently had a similar problem with my fridge. The service guy did his thing then left and it stopped working a few days after. He then came back and said he did not pressurize it sufficiently.AC not working again. Maybe about a month since last service to fix the same issue. Last time the excuse was no refrigerant from factory. Don’t know what it will be this time. Haven’t seen any evidence of a leak, but acting the same as last time. Toggle on AC or Max and it auto toggles to off after a few seconds with no cool air. Calling SC tomorrow for an appointment. If second fix isn’t permanent going to have to start talking buyback.
If it is indeed leaking they need to replace the component or reseal everything or both not just service it. Refrigerant evaporates so a leak does not mean you need to see fluid for a slow leak to be there. We are talking about a pressure leak.
