MatC21
There are two levels of Apple Car Key.
The basic support requires the phone to be touched to the door handle and the phone to be on the middle console for driving. That's what some older BMW models have. This is using NFC.
There is a 2nd generation which works with UWB that works like the regular key fob and means you can leave your phone in your pocket. This is what some newer BMW models have.
nulled
nulled
did you do any OTA or any other thing from your dealer?
No OTA or dealer updates. They might be changing things without updating the OS itself. It seems that every part of the OS is running as an app, so they could be tweaking things all the time.
tolsen
ted
ft lauderdale
macan 4, tesla m3, jaguar ipace
sounds reasonable i was checking out available apps yesterday and noticed tidal, a music streaming app, that wasn’t there several weeks ago. i also noticed the digital key app. looks like they are pushing new apps and app updates to the cars. lets hope the next step is an update to the phone app that includes the digital key support
Electric Macan EV Phone as Key is coming - found option called ‘Digital key’ in PCM 1742821101990-5y
nulled
nulled
I think their marketing/PR team must be sleeping… Each thing you mentioned could have been a separate press release. Tesla used to make big noise from launching Apple Music, Tidal, etc.
anders1
Anders
Sweden
Volvo XC90 T8
Agree. Ultrawideband has a longer reach. NFC just a few centimetres. So for a practical point of view UWB is the most likely choice
does android have a comparable app?
you think they would launch a car feature that only works a subset of their audience?
Dragon Tourniquet
Nevada
When the BMW iX launched, initially phone as key was only available on the iPhone. The main reason is because there is a single API to target all the iOS users, but Android has different APIs for different manufacturers. Eventually support came to Android platforms, one manufacturer at a time. I wouldn't be shocked if Porsche and Audi do the same thing.
dont you think that car key on android is a security risk?
Dragon Tourniquet
Nevada
I don't actually know Android well enough to say, as I'm an iOS user (and sometimes developer). But from a dev perspective, the fact that it is different APIs for the different wallets and UWB chips is a problem. Fragmentation makes it less worth doing.
with "baseline" being existing FOB's and their wireless design/communication/protocols - it's hard to imagine iOS/Andriod being "less" secure than any existing physical FOB's
also asking what is or is not secure with out identifying the "attack vector" you're defending against is also a bit of a fools errand…
these days for me personally the biggest attack vector for all of this stuff is "radio frequency band relay attacks" - i.e your car in the drive way and your key inside your home - the bad-actors deploy radio boosters to "relay" your FOB's radio signal to the vehicle's proximity to fool the car into thinking the key is "near by"…and then start the car and drive off…this one is hard to defend against and the only effective solution is to store your keys inside your home in a radio blocking container so that there is no radio signal to amplify/boost…
having reviewed the BMW/Apple "phoneaskey" design phone-as-key is vastly more secure against most attacks vectors than _ANY_ existing FOB - so phone-as-key is not likely to be the weak link in all this - the Android stuff while fragmented due to API disparities is also unlikey (impossible?) to be worse than a FOB and I would suggest if it's not as secure as iOS it's close enough as to not mattter…again vs. a FOB these phone based implementations are much much more secure, and more importantly more actively developed, patched, and modified on a continuous basis…
but bad actors are always working against the systems, and it's always an arm's race…
having reviewed the BMW/Apple "phoneaskey" design it's vastly more secure against most attacks vectors than _ANY_ exsisting FOB - so it's not the weak link in all this - the Android stuff while fragmented due to API disparities is also unlikey (impossible?) to be worse than a FOB and I would suggest if it's not as secure as iOS it's close enough as to not mattter…again vs. a FOB these phone based implementations are much much more secure, and more importantly more actively developed, patched, and modified on a continuous basis…
you are right
QuiteBig
Steve
Macan electric 4S, BMW 440i, Mini Cooper electric
We got an electric Mini in January, and that has a very nice implementation of phone as a key. We have never used the actual keys, we just walk up to the car with our phone in our pocket, the lights flash when a few feet away, get in and drive off.
This did in fact prompt me to urgently contact Porsche to change my pending order and add comfort access back in late Jan. They managed to get in it days before build, and I picked up my 4S yesterday. I was very pleased to see this thread, which seems to justify my change if the rumours are true, as I am sure, as others have said, it will depend on comfort access
jsclarke
Orange County, CA
Macan 4S (EV), x2
I traded a 2022 BMW iX in on our Macan 4S, which had Apple Car Key.
It wasn't perfect.
It did work properly 95% of the time though. When it didn't- you had to open Apple Wallet and select the BMW key near the door handle to open. These were panic'ed "uh oh" moments.
So, we carried a BMW credit card key as a backup and for valets.
That key, in turn, worked 2/3 of the time (even tried replacing it but same). So, at restaurants with a valet, I had to give the valet my iPhone to park the car a few times. Every time a valet was using the card key, I worried that it might not work especially when waiting for the car.
On trips, and whenever I expected someone else to park the car, I took the key fob. So I consider this promising, and *almost* but not *totally* there yet.
Dragon Tourniquet
Nevada
It wasn't perfect.
That sounds like there was some kind of problem with the readers in the car. In the 3 years I had my iX, I never had to fall back on NFC on the phone, and so long as the valet put the NFC card in the correct spot there was never a problem with that either. The only time I used the fob was when I took it in for service (because they require it).
