- First Name
- Inez
- Nov 27, 2024
- Canada
- Macan 4
Yea the same happened to me. I was unable to reset and had to power cycle by unplugging it completely. It hasn’t frozen again since, but now the red lights flashes every time when connecting charger to the car’s charging port. It still charges, thank god. But I can’t help feel uneasy about it because what if left unchecked it could cause more serious problems. So perhaps you could also look into whether the electrician used the proper NEMA socket and if it was properly grounded etc. I am trying to get the electrician to come back to fix things. Will update post once they’ve rectified the issue and will let you know if the flashing red lights goes away after the fix.I had the exact same thing happen with mine. In my case, I've used the charger in the 50% mode for several months. A week ago I switched it to 100% and charged the car. After it charged I noticed the red lights. I disconnected and figured it would reset itself...several days later I noticed the lights were still red and no buttons would do anything...so I removed power and it came up normally. Did another touchup charge with no issues.
