- First Name
- Tim
- Jun 13, 2025
- Colorado
- 2021 Ford Mustang Mach-E FE, 2025 Porche Macan Electric
So for instance, if we're on a road trip 10 minutes from the next DCFC stop, and we're not using the car's nav (not sure if it automatically preconditions but some EVs do is using native nav), then we could kick it over to Sport+ if we wanted to warm up the battery for a potentially faster DCFC charge (at the expense of a little range)?Correct.
Pre-conditioning the car in my previous E-tron also heated up the battery but just a bit (using the excessive heat from pre-condition als traverses the battery pack) Not sure about the Macan but this morning I used pre-conditioning and battery temp was 11 degrees Celsius on entering the car but outside temp was 6 but I did not check up front if the battery cooled down to the outside temp or not.
