Preconditioning & charging planner
I have something to say about rebalancing, but I’m collecting a bit more information. I suspect there are some quirks that can be triggered with certain usage patterns that account for some charging issues people have posted. Nothing super surprising if you’ve followed Taycan forum info.
The reason I brought it up in context of preconditioning is because rebalancing can also be a fix for poor charging speeds. I don’t necessarily think the current implementation can rebalance a running vehicle, just an “it would be nice if” comment.
Interesting!
If you find something please let us know. Nice project you did with the data logger.
I guess rebalancing can only be done while charging, the high load you demand on the HV DC makes it in my option more complex to rebalance while driving, I think enabling that from a hardware perspective would be a costly endeavor as different cells will differ in voltage drop under load.
So hence all the cars I know do it when they reached there charging limit and start by either:
-Passive balancing, discharge higher voltage via resistors, that is the old way
-Active balancing, move charge from higher to lower via capacitors or inductors: more efficient less heat.
Just a rough data point, I entered A ChargePoint close by when running some errands.
Ambient 12C battery 11C went up to 16C after 30 minutes so at ambient 12C it seems to gain 5C per 30 minutes.
I left the charge destination in the Nav and started pre conditioning in the App when at home… The battery is up to 19C … probably the thermal mass catching up with the sensors, but maybe Porsche has bug in the system 🤞
Here is an interesting test in winter conditions of Macan, Audi Q6 and Polestar 3:
They compared charging without preconditioning and turns out...
"With no pre-conditioning of the batteries, the Porsche Macan initially struggled, and achieved a disappointing charging speed of just 30 kW. The Polestar 3, limited by its 400-volt architecture, reached a peak charging speed of 80 kW. The Audi Q6 e-tron fell in between, and reached 100 kW."
Seems it's not only some people on this forum that complain about abnormally poor cold battery performance.
It’s an interesting video and something to keep in mind. He says 17°C battery, which is really not cold at all, I think there’s more to the story. Indeed after watching the video they realized the charger wasn’t on its own circuit and got much better speeds after moving the Porsche to another charger. Timestamp 16:50, got 125kw right off.
I type this as I sit right now charging my car after a 2 hr drive in freezing temps. Not trying to be argumentative but just explaining why I personally don’t bother with precondition. I am not telling anyone else not to use it, nor that it’s worthless. Just don’t want to be called “ill informed” for saying that I haven’t found it to do much for me.
I went to pick up my skis from the tuning shop, it’s a little less than an hour away so I can drive there and fast charge on the way back closer to home.
Started the morning out at 30°F/-1C. Nothing special done to precondition. By the time I was getting close to the charger the outdoor temp was 37°F/3C and the battery temperature was 57°F/14C (lower than the video, they say battery is 17C!) just from driving. When I finally stopped I had a much lower SoC than the video at just 3%.
Electric Macan EV Preconditioning & charging planner IMG_0290
Electric Macan EV Preconditioning & charging planner IMG_0305
Just finished and pulled into another spot to finish up this post. The chargers were balanced and the station was packed, so I feel like it could have done better. Still I managed to go from 3%-73% in 22 minutes, peak speed I saw was about 206kw (probably due to balanced stations).
Electric Macan EV Preconditioning & charging planner IMG_0309
This is the sort of experience I’ve always had in EVs driving in winter, sometimes on 500 mile trips.
I noted that the battery jumped to 85°F/29C within the first four minutes of DC charging, and after ten minutes it was at 107°F/42C. So even if it just wasted a few minutes getting the battery temperature up to the sweet spot, no big deal for me.
Well I watched it too and 123kw is what I see as well … as do others … so lucky you. The questions now is why do you see 200kw and others not?
I have done this test a dozen times at a station where I know I get 270kw and most of the time I’m the only one charging so we can eliminate the station.
When was your car build, did it had the software update, curious to see is they changed something in the meantime …
My car is one of the first and received the update …
And not to be picky, but you are not showing the charging and the temperature in the same shot … In fact you are not charging when showing the battery temperature …
The pictures I posted Clearly show me charging and temperature, both are shown in the circle …
Maybe our heaters are not used, as you can see the charging does hardly heat the battery at 123kw, I only see your heating speedup when charging above 200kw …
And you do the same 70% charging in just a minute more then the official 21 minutes, that charging curve must be super flat as well 👍🏻
They were already at 37% charge which, I didn’t have 200kw either at that level. It is somewhere around that point where even in optimal conditions it starts to drop below its max rate, my guess is that within a few minutes they might have bounced up a bit over 150 with the warming of charging, but we don’t know.
No software update yet that I know of. Got the car in September, there’s some rumor about the update having been available to factory before dealers in Nov and I have no way of knowing what version it is really on, but I have an appointment for later this month and will find out.
Reviewing marketing materials, they claim it can hold max charge to 35%, but also that it is possible to see 200kw up to 55%. So clearly I was derated not seeing 200kw between 40-55% but perhaps made up some difference toward the end by not having a completely cooked battery. Not sure! My battery was certainly warmed up judging by the readout, if that can be trusted.
My battery has also recently undergone a rebalance so this could be throwing things off.
OK so you have probably newer hardware … my car is a year older, like in the video. Still strange you do almost advertised time with a lower charging speed. So not only do you charge about 2x faster then some of us, it needs to charge faster over the complete range as well. Interesting.
I took the battery temperature shot while driving , and later after charging I took a shot of the charging display in center screen.
To get charging rate and battery temperature together, here’s one took just a minute or two after my last shot. Looking at the timestamp it had been charging a little over four minutes at this time.
You can see that the battery temperature is already jumped into the sweet spot. You can also see that it is starting to dip below 200, but the readout is really quite bouncy and jumped between 195-205 for the first five minutes or so.
At any rate the point for me isn’t whether I got the max possible performance in winter, it’s whether it’s fast enough for me not to worry about it or it being worth switching away from my preferred navigation.
Electric Macan EV Preconditioning & charging planner IMG_0307
Ah that explains it, it all makes sense now … the strange thing is that you get higher speeds ones your battery is in the Goldilocks zone. Maybe the trick is then to drop the charge to under 10% and is the internal resistance higher and so it heats quicker … makes more sense now. Should do a test at very low charge to see if that is the “trick” though your car charges faster and it does jump to a higher charging speed which none of us observe … to be continued.
@sor A shame you did not get a picture of the start of a charge, my battery always increases temperature when you drive the car Low on charge, the internal resistance of the battery goes up and so does the heat generation. I’m quite certain the trick is indeed running it very low, which is something you can do if you are 100% sure you can charge at the destination. When roadtripping I will take 10% as a minimum … next time I‘ll try to munster the courage to drive it lower.
How did you do it?
My Strategy is charge to 95% and let the car sit for at least 6 hours … (95 as it start at 90% and do not want to run the risk the drop in % )
I never heard of bottom balancing, if that is the case I would like to know how certain we are, if it really is a thing it can explain why some of us have different total range estimates.
There’s some documentation out there, most of it is general like for solar batteries, and on random websites. I agree the details are opaque as far as what each manufacturer does and there’s some conflicting info about it - some say bottom balancing is only a factory thing.
It’s confounded by the fact that tech changes quickly and some of this information is 10 years old, which is an eternity.
One thing I read that makes sense to me is that bottom balancing is more about ensuring the cells are all empty at the same time, they all have the same zero point. If their capacities differ slightly or degrade at different rates over time then for an EV it is more important that the BMS can drain them all to 0 than it is for the BMS to be able to make them all the same voltage when “full”, since you can’t run an EV on the energy from just a few cells that didn’t get drained.
https://diysolarforum.com/threads/top-vs-bottom-balancing-and.2801/
BOTTOM BALANCE:
A bottom balance simply means the cells are balanced at the lowest “safe” voltage and all cells will converge and match exactly at say 2.75 VPC. In the EV world bottom balancing is almost always the preferred method, and makes the most sense. With high loads, and frequent opportunities to completely drain the bank, a bottom balance is critical with an EV pack.
