- First Name
- Yves
- Jan 28, 2024
- Belgium
- BMW iX / Macan Turbo
Correct, the AC charging will keep the battery from loosing all the heat generated during the DC charge, it will not heat the battery, just slows the cooling …thats all ok. but i do not understand: „I DC charge to 70% and charge the car to 100% on AC, it is outside so if I do none of that my battery is very cold“
you go to a fastcharger, charge to 70% than drive home, park on the street and charge to 100% with AC? this would not make much sense.
anyways when you leave with 100%, use the charging planner, you will have a perfect battery temp for your next charging 3 hours later.
the point exactly is that this is very complicated and not very significant at the same time.
thats why porsche researched this for many years now und came to conclusions. oneof this conclusions must be that we get better results if the cars computer calculates whats most efficient.
I have 3 DC charge stations all very close to home, like one is at less then a mile out …
As you have seen I advised other people to skip this, I like to get 100% efficiency, others can ignore or adapt to it …
If all goes well I will do the trip to the south of France with the Macan in colder conditions and I can report back on my charging time.
2 years ago with the iX it was not that great, used Apple Maps / BMW nav and the iX had no manual pre heating so I ended up 1h45 minutes charging …
If I can keep it under 1 hour this time, I’ll be happy …
The BMW App gives Charging time 1h8min and 3 stops
The Porsche App gives 54min and 4 stops …
