- First Name
- Yves
- Jan 28, 2024
- Belgium
- BMW iX / Macan Turbo
Interesting!I have something to say about rebalancing, but I’m collecting a bit more information. I suspect there are some quirks that can be triggered with certain usage patterns that account for some charging issues people have posted. Nothing super surprising if you’ve followed Taycan forum info.
The reason I brought it up in context of preconditioning is because rebalancing can also be a fix for poor charging speeds. I don’t necessarily think the current implementation can rebalance a running vehicle, just an “it would be nice if” comment.
If you find something please let us know. Nice project you did with the data logger.
I guess rebalancing can only be done while charging, the high load you demand on the HV DC makes it in my option more complex to rebalance while driving, I think enabling that from a hardware perspective would be a costly endeavor as different cells will differ in voltage drop under load.
So hence all the cars I know do it when they reached there charging limit and start by either:
-Passive balancing, discharge higher voltage via resistors, that is the old way
-Active balancing, move charge from higher to lower via capacitors or inductors: more efficient less heat.
