- First Name
- peter
- Dec 23, 2024
- Austria
- Macan Turbo EV, porsche 911 limited edition, GMC Sierra Grande1971, Smart Brabus
1) air density: up to 20% more consumption (suv)I think that there are two somewhat independent things going on in cold weather. First, the car consumes more to heat the cabin and presumably to manage the battery. Second (and I am, less sure about this) the battery looses effective capacity in the cold. The battery likely loses efficiency in the cold, so it cannot deliver all the energy that was stored into it, so range is reduces as electrons are lost in the cold battery. This would imply that the range can be improved if the battery is preconditioned before departure, more so if the car is plugged in before leaving so the preheating is powered by the charger and not the battery. So in the summer, you can estimate range given the consumption (assuming the battery is able otherwise deliver all its capacity) and you would see a lower range in winter (even if consumption is the same) in winter. Combining more consumption to heat people/machine and lower effective battery capacity means a double hit to range.
2) rolling resistance 15-30% higher at 0 C (32 F) than at 20 C (68 F)
2) heating (cooling) up to 6kw/ hour (no sense to waste energy on preheating of battery before a drive)
3) battery loss has minimal impact on range, but significant impact on performance. both too hot or too cold. therefore sport + starts preconditioning right away.
everybody can test this in engaging sport+ in very cold weather.
(in your case it was the charger)
