VR28.13 Software Update
mutro
NA
Don't get me wrong... I love my Porsches, but they need to stop making excuses and deliver software that actually works. The latest software update required me to leave my car with the dealer an entire week. But the update created more problems than when it went in. Yes, we drive Porsches because the drive is incredible, second to none. But if they are going to sell options that promise driver assist at high added costs, they should just work, period. And we as drivers should stop making excuses for Porsche and expect that they deliver on what they promise and what we paid for.
MatC21
This is true. As much as I love my Macan and Porsche in general I am not sure I would go with one of their EVs instead. The Taycan quality is disastrous and the Macan is not much better. Having to bring in the car for a Software update and not even receiving the latest My2026 update is just bad.
Just a quick update. Had the latest software installed over a month ago on both of my 2024 Macan 4‘s. Zero error messages since then (I did have a few, not many, prior to the new software).
just FYI (prior post above), MY 2026 software won’t be installed ever in 24’s and 25’s because the hardware is different.
Tom905
Toronto
Macan 4S, Q8 e-tron
I dropped my car off today for this update, they say it won't take and they need to keep the car into next week. Anyone else have this issue getting the update done? I had almost no issues with the car before today (Mainly android auto connection issues and the electrify Canada cert not working), so now worried that the update is going to break it....
I've read of a few here. It is common for one module to fail update the first time but it usually takes on the second try. Sounds like yours is not taking on the second or third try.
From what I've read here, once they figure it out there are no further problems with the car. There are a few reports of it taking weeks, however.
Tom905
Toronto
Macan 4S, Q8 e-tron
Thanks for the response, late last night I got this from Porsche: "The tester was having trouble downloading the update before it even started to program the vehicle. We have put the car to sleep / tried with a different tester and it's going through as we speak." Apparently the tech stayed late, and they finished my car this morning. Just got it back, hope all is ok...
RunningOnSolar
Scott
Ohio
Macan 4, Subaru Solterra
I've had the update for about a week. It took more than one try to install for me also. I've had no spurious warnings and driver assist features are working fine. The only negative I've noticed is the navigation range estimates are now wrong in a different way. The estimates used to be pessimistic and now are optimistic.
I was out on the highway today and for the first time since the update I noticed that blind spot was not working. Weeks ago I saw an assist system error without description for a moment but otherwise no errors reported. I cleaned up all the cameras but I think blind spot/rear collision warning primarily uses RADARs.
EDIT, I just saw a post that closing and opening the side mirrors fixed this, I'll have to try it.
So never mind, closing and opening the mirrors did the trick.
MatC21
I have an interesting observation regarding the “big” update. I had it done beginning of the year after a workshop visit.
Now this week I had to bring the car again to fix some GPS issues. They said they reset some controllers but did not mention any updates. Now suddenly my speed limit chime has a different sound (a much better one!).
So either there is a second update or the big one was nit properly applied. I did have 5G after the first one though.
Degenatron
Macan 4, Mini R57
I had the update done later than most on 19/03/26 and assumed that the new and less invasive speed bong was part of the original update.
It sounds like your first update was applied correctly, so this stands to reason there must be a 2nd version of the update?
MatC21
Well, 28.13 is meant to bring 5G and I had 5G after the “first update”. I think my car either came with 28.11 already or it was done together with 28.13.
