- First Name
- David
- Jan 28, 2019
- Santa Cruz
- Macan Turbo,Cayenne Hybrid, 911(s) GT3/Convertable
thank you for this update - I'm particularly pleased that the pre-update Macan "just worked" and the post-update Macan did not work (as expected) - having a reproducible test case that exhibits the problem (or not) is normally "key" for any engineering progress on a software bug…So, small update after the Porsche engineer visit.
Spent half a day logging everything at my home, both with my car and another test Macan without the update. As expected, the pre-update Macan charged with no issues.
One unexpected resolution was found by accident during testing - after plugging the car to charge and during the initial clicking of the wallbox, switching on a high power appliance bumps up the baseline (don't know which parameter) and the car starts charging. In my case an air compressor was used for this purpose multiple times, also, switching on the central vacuum system worked on the test Macan. Not sure how reliable this is, I will test this more in upcoming days - as the car is charging now
Long story short: Porsche will now analyze the data collected and are confident that the solution will be found shortly.
I have high confidence they will figure out what the core issue is given that they now have data logs of a working and non-working Macan.
