So, small update after the Porsche engineer visit.
Spent half a day logging everything at my home, both with my car and another test Macan without the update. As expected, the pre-update Macan charged with no issues.
One unexpected resolution was found by accident during testing - after plugging the car to charge and during the initial clicking of the wallbox, switching on a high power appliance bumps up the baseline (don't know which parameter) and the car starts charging. In my case an air compressor was used for this purpose multiple times, also, switching on the central vacuum system worked on the test Macan. Not sure how reliable this is, I will test this more in upcoming days - as the car is charging now :)
Long story short: Porsche will now analyze the data collected and are confident that the solution will be found shortly.
thank you for this update - I'm particularly pleased that the pre-update Macan "just worked" and the post-update Macan did not work (as expected) - having a reproducible test case that exhibits the problem (or not) is normally "key" for any engineering progress on a software bug…
I have high confidence they will figure out what the core issue is given that they now have data logs of a working and non-working Macan.
But if the issue is not voltage and it's TDH, turning on appliances that are contributors to this, increases the TDH which makes it deviate from the ideal range, and that's not what we want. I'm assuming you want less TDH and more frequency stability.
voltage sag's when there is a big draw…it might get lowered by as much a 5V
nick729
Lithuania
Macan Turbo, GLE580, FFR Type 65 Coupe LS427, C63AMG
I had taken 2 different Macans from the dealer about a month ago and tested them myself. One was pre-update, so they already knew the outcome before testing it themselves. Engineers flew in yesterday and they were downgrading one of the Macans to the pre-update version for testing and benchmarking i assume. After data logging the pre-update Macan was updated on the spot and as expected it stopped charging :)
this is soooo good! _PROOF_ the software update _IS_ the root cause of the problem!
annwills
Orchard Park, NY
2025 Porsche Macan 4S
Allow me to add my thanks for taking the time to keep us informed. This appears to have been a thoughtful, honest and logical reaction to the problem by Porsche Germany. Wonder why no one at Porsche NA bothered to take the same steps and instead kept us in the dark for 3 months.
That is great; although if I understand correctly, that test was on a three-phase circuit. Let's hope it generalizes to the North American single phase scenario also.
even if it doesn't there is now precedent for power-voltage-quality issues causing problems for Macan's to charge - and the the update is the reason it no longer works - now as to if the fix for Europe does not fix North America - well it's not forgone conclusion it _IS_ the update that is causing the faults - and they may need a different fix for North America, but either way the current update has a very very bad fleet wide regression that affects charging…
this rules out PCNA blaming the victims…
nick729
Lithuania
They are aware of the issues in NA too, I have referred them to this thread a while back and also talked about it this morning.
I'm not disagreeing in principle. But... it's not apparent to me whether it is PAG, PCNA, or individual dealers/service writers/service managers, or some combination, who are blaming the victims.
Reading through the posts here, Porsche's entire approach to the EV's nets out to blaming the victims, which is terrible for Porsche as a brand, and for Porsche loyalty, and really seems inexcusable to me. I mean, responses such as, "you're using the wrong EVSE" are truly horrendous, and the whole system from top to bottom, which resists clarity, communication, accuracy, honesty and accountability is quite disheartening.
Speaking for myself, I was willing to order a Macan EV sight unseen because I trusted Porsche. So far, I happen to have lucked out, in that after 17 months and 12,000 miles, my Macan 4 (so far!) has been great. But every day I get into it there's this little buzz in the back of my brain, and I am not too likely to trust Porsche again. With 7 months left on my lease, I am now really torn because as much as I do love this car, I am no longer comfortable with Porsche.
lukine
lukine
Inez
Are you one of the owners who isn’t able to charge at home? I completely understand where you’re coming from. I’m a first time Porsche owner, and I expected much better from a luxury brand. Unfortunately I did not lease the car, I purchased it, so there will likely be less options for me and most likely my options will require me to either take a big loss on buy back value or put in a lot more to buy new one. I do love the way Porsche cars drive. I even went to the Porsche Ice track experience last month in Montreal. And it was really fun. But this ordeal has been a huge turn off. The way they have responded to this issue has been way too slow, and disappointing to say the least. They’re tarnishing their own brand by putting the blame on owners or “external influences” instead of taking accountability. All in all, I wouldn’t recommend Porsche to my friends anymore.
No; since I have been fortunate so far in not experiencing the issues the update is apparently intended to address, and seeing the issues some people are experiencing post update, I am taking the approach of not fixing what isn't broken (i.e. deferring getting the update until either I need it or it is evidently fully baked.)
My comments are really a response, in general, to PCNA's and dealers' inability to address the various bugs people are experiencing, but the issues with this update are an especially clear indication of where Porsche is going wrong in my view.
(If I were not an avid automobile forum participant, based on my own experiences alone, I would think everything is great! (Again, I superstitiously say, "so far.")) My personal Macan EV experience has been great to date. And yes, I know that the tendency is for people to come to forums when they are having problems. I am saying this more as an observer of how apparently incoherent/inept/inadequate the service support for these cars has been and continues to be.
bejoneses
BRyan
San Diego, CA
2024 Macan 4 EV
Adding one more example. Software was updated about a week ago, and now home charging is flaky. I can consistently charge early in the AM, but am not able to charge in the afternoon / evenings. Kind of feels like this is pretty consistent with the voltage sensing that others are suggesting...
  • Year and Model: 2024 Macan 4
  • Your Location: San Diego, CA
  • Charger at Home: Morec 32 (cable - plugged into 240V outlet).
  • Charging Port: BOTH
  • Timeline: Started immediately following a software update.
  • Troubleshooting Steps Taken: None other than changing when I try to charge
  • Current Status: Just working around the issue - no actual fixes
Paul
Porsche Macan S 2019, Macan 4 EV 4WS
Adding mine:
  • Your Location: Boulder, Colorado
  • Charger at Home: SPAN charger
  • Charging Port: Both
  • Timeline: Immediately after the software update. It was working fine previously with the same equipment.
  • Troubleshooting Steps Taken: None. I use the expensive public chargers now.
  • Current Status: I called the dealer yesterday. They said "Porsche knows about the issue but no fix yet". Coincidentally, my SA also has a Macan 4 with the same issue since the SW update.
loudsnorelax
United States
BMW X7
  • Year and Model: 2025 Macan 4
  • Your Location: Annapolis, Maryland
  • Charger at Home: ChargePoint Flex
  • Timeline: My story is a bit different. My update was performed in December. I had no issues charging at home at all after the update. On 3/2/26 my house experienced a power outage for roughly 5 hours. I was told by my neighbor that we were also on only 1 phase of electricity for about 3 hours as well. After that - my charger experienced the red ring of death and refused to charge. Was sent a replacement charger. This new charger cannot charge the car.
  • Troubleshooting Steps Taken: Chargepoint asked me to try a public charge point charger. The fast charger worked, the level 2 did not. Went to a different provider level 2, and that failed as well. Went to the dealers level 2, it failed as well.
  • Current Status: Talked to the service advisor at the dealer. They immediately provided me a card to use their level 3 charger free for a year. They are well aware of the issue and stated that even when a new update comes out, they will not be putting it on customers cars until they are confident it fixes the issue.
jergans
NY
I’m having a similar issue as you. I do not think that our issue is related to the software update as (1) we both had no issue with home/level 2 charging for a while after receiving the update and (2) no level 2 charging (or level 1) works at all for us. That is different from most of the cases here.
At least you got free charging for a year. My car has been at the dealer for two weeks with no communication or response to my inquiries.
