- Sep 3, 2024
- Pennsylvania
- Audi TT Roadster, Ducati Panigale, Cheverolet Trailblazer, Kia Sportage Hybrid
lol yes thanksUnplug?
I have an appointment to bring the car in next Thursday. Not sure if they allow customer to request what to do with the vehicle. But I can mention it to them. Thanks!@lukine you should just get them to downgrade the onboard charger software. I had this and it works flawless now. I'm sure in the future they make have a version that doesn't break charging, but it was just not worth it at this point. the Super Chargers here are 70c a kw/w so charging at home is something that needs to be available all the time. at these charger rates at the electrify canada (up until recently) you would have been better off with a petro car (when you take into account operating costs and capital cost vs opportunity cost of that money in the market).
This downgrade for only the onboard charger was the only thing that 'fixed' the charger issues for me. I had the charger patter alerts you showed until the downgrade (not the whole car, just the charger software).
You can absolutely do this. I had a problem with the HUD fading out in the sun sometimes. I found the workshop document that detailed this, and, on the second attempt, gave them the specific document number which they then ran through to fix my problem. The first time they simply turned up the brightness of the HUD.Not sure if they allow customer to request what to do with the vehicle
They should. All you have to do is explain to them at that you can't charge at home on AC, post software installs, DC charging still works fine.I have an appointment to bring the car in next Thursday. Not sure if they allow customer to request what to do with the vehicle. But I can mention it to them. Thanks!
Well, for those interested, as an update, after taking the Macan in on April 17, we finally got it back yesterday from the dealership! They had initially tried to apply the ATI #2604 roll-back and completely bricked the computer. It was non-operational for weeks! Porsche instructed them to replace the entire computer system and retry the update. After several attempts, it is finally back and can charge at home. What an absolute nightmare.So is Porsche sending out this update, or do I have to contact my dealership? And then, is it going to be a crapshoot if my particular dealership will even understand whether this fix that some of you are getting is something that they are capable of doing? So far, Livermore Porsche has not been able to solve my home charging problem. (I am in the boat of it used to work with the new update, and then abruptly stopped a month or two after)…
@Flying4Fun, this was the roll back that they performed under Bulletin #2604. My Macan 4S had already been updated to 28.13, so there are no newer updates past this one. What the roll back does is bring the High-voltage control box back to software level 0346 (vs software level 0449 under 28.13), while leaving all other components updated correctly. In my case, the dealership screwed up the process and fried the whole system, bricking the car. They had to replace the entire computer, redo the software update, and then roll back that one component to get it back to me so that it can now charge at home.@SeaMonkey80 is the final state you ended up in is a Macan with the 'roll back' for the on-board charger? or is there a newer update to 283.13 that fixes the charger issues without the roll back.
I've had this happen - only once so far. The HUD continued to work, so the car was drivable. Here's the photo I sent to my service advisor showing the complete lack of dials. The 'Park' text goes away when you put it in Drive. Note the PCM screen still works. This was not after a DC charge, as the EA site was full - I had planned to charge here, so pre-conditioned before this stop.the dash LCD went dark
That is exactly the condition of my screens and systems (I don't have a HUD). The back of the cluster screen was pretty hot, but outside air temp was only 18c - and not even in the sun was in a shadow.I've had this happen - only once so far. The HUD continued to work, so the car was drivable. Here's the photo I sent to my service advisor showing the complete lack of dials. The 'Park' text goes away when you put it in Drive. Note the PCM screen still works. This was not after a DC charge, as the EA site was full - I had planned to charge here, so pre-conditioned before this stop.
Mine does this too in the UK. I have Hypervolt Home Pro 3 charger and was with OVO and am with EDF now. Car keeps changing the departures. I override by toggling the Direct charge and after 5 minutes the same thing happens again.Hi,
I recently had the update but my issues with charging at home may be related.
I hope that helps. Otherwise no other issues with update and my SoC % is updating unlike prior to update.
- Year and Model: Macan
- Your Location: UK
- Charger at Home: Ohme Charger
- Charging Port: Only tried one side (driver)
- Timeline: Observed on first charge following upgrade
- Troubleshooting Steps Taken: New feature in app allows to toggle for direct charge, appears to allow charging to take place. Also constantly needing to delete planned departure. Utility company also appears to have option to now turn off economic charging. Option was previously switched off.
- Current Status: The car keeps attempting to default to economic charging and recreating planned departures so deferring the charging. Have managed to charge via the home charger keeping an eye and toggling direct charge on several occasions.
