Could be covered under warranty ? Sun roof
noelnp
Múnich
macan ev 4
Hello ! First post , macan 4 ev , 14 months old…..no issues so far except recently this one on the sun roof , could be covered under warranty ?
Electric Macan EV Could be covered under warranty ? Sun roof IMG_8138
Raphie
NL
Porsche Taycan 4s (21)
Something from outside scraped that badly, you can see the path, don’t think that’ll be warranty.
Corporate would claim "external influence" and will not cover under warranty.
Fly4ever
Seems like the driver tried to pass below something without the adequate clearance and hit. Definitely not be covered under warranty IMO.Best bet an insurance compensation without any deductable amount for such a damage!
noelnp
Múnich
macan ev 4
Any clue if it is going to be a
Complex fix ?
Timcat
Wiltshire, England
Macan Turbo EV, 992.2 911 Carrera T
This was most likely caused by a bird, specifically a crow. Look it up on Google, crows are known to damage sunroof seals, particularly those surrounding highly reflective glass roofs. The damage looks just like that in your photos (I have seen it in the past) when it starts. Unfortunately, once they get a taste for it, crows often come back and add to the damage. I live in a rural part of the UK where there are a lot of crows and, for cars that will be kept outdoors, never order sunroofs for this reason.
The damage in your photo is to the outer seal and, therefore, will not allow water into your car. If I were you, I would leave it alone and see if the bird returns before spending money on replacing the damaged seal. Replacement is not difficult, but Porsche parts and labour costs make it a little expensive.
loid55
Taycan GTS 2022
If it’s a mechanical failure and not glass breakage from a rock, the bumper-to-bumper warranty usually covers the motor and the track assembly. Get the service advisor to document the fault code before they try to blame external damage. I had a similar issue with a sticky seal and they fixed it without any pushback.
