- First Name
- Eric
- Aug 7, 2024
- US (Georgia)
- Macan 4
Do you mind sharing which Model you used from fitcam (A/B/C)? I haven't given it enough of a look, but Fitcamx cannot use the factory pre-wire, correct? Meaning you have to go to a fuse box to hardwire, or did you go to the sensor wire in the overhead console as they suggest?I just installed my front a rear fitcam yesterday. For the most part the videos online show enough to get it done. There is video of a guy who installed one on a 2024 cayenne that was helpful. everything came apart and went back together relatively easily. I found it easier to install the camera and route the wires and then put the mirror back on. Routing the cable to the back took some time, and getting it through the grommets to mounting place took some time.
