Tires are deliberately overinflated for transport from factory. Dealerships should adjust downward to stated on lower B pillar but more than a few Techs forget to do so.
GORGEOUS ride Innuendo, worthy of another look!
Electric Macan EV New Macan GTS real-life images IMG_2008
MTGBUK
Hey MTGBUK can you tell us if there are any PPF seams on the front bumper or did they manage to go a bulk install to skillfully avoid creating seems along the front? Ask this because if they use a template sometimes they have to seem together two pieces, in visible places which end up collecting dirt whereas if they do a bulk install, although it’s more difficult, they can do the entire bumper with one piece instead of multiple pieces.
Hope this goes some way to explaining. Front bumper is different and is 2 pieces on the Sport design/GTS.
It does I think. From what I understand the seam is hidden underneath the front lip (good). It looks like the rest is one piece (I hope). Usually when the digitization has been done, it’s available to all shops in the Porsche database so I was a little confused as to why an individual shop would need to digitize it to create a template but perhaps I misunderstood what was being said.
MTGBUK
Available templates were only suitable for the Turbo, 4s and 4. There are considerable difference with the GTS meaning new templates were required. My car was kind of a guinea pig. Thankfully my detailer has a very good relationship with Suntek and was able to get them to out to create the new templates.
Andy718S
Andy
Macan EV GTS, Boxster 718S (Macan EV 4S now sold)
My PPF guy contacted me a couple of days ago to advise that templates are now available for the GTS. My car is booked in on Monday.
MTGBUK
If he’s using Suntek I’m guessing the templates will be the ones create using my car.
Electric Macan EV New Macan GTS real-life images fe61db54-9758-4605-846c-9e990f6a75d
Electric Macan EV New Macan GTS real-life images 7a3710e2-73f3-4b1b-b93d-12890968f39d
Electric Macan EV New Macan GTS real-life images c56c4ce6-e03c-41ce-813b-030c5970fa97
Andy718S
Andy
That could well be! He’s going to make any pieces for me that are not in the templates file.
Stuart
Stuart
Amsterdam
Check the plate on the b-pillar visible when the driver's door is open - this will be the recommended pressure for original tyres and rims fitted.
So went to the dealer, and they were very confused as well, said they would create a case with Porsche HQ, as there is a difference in tyre pressure details in the TPM and the sticker on the door pillar.
The pressure for normal load 3.0 bar is correct/matches on the TPM & the sticker.
The pressure for partial load is 2.7 bar on the sticker and 2.5 bar on the TPM, I pointed out that a difference of .5 bar between normal and prtial load seemed alot and they agreed, so they think the sticker is correct and the TPM is wrong for what ever reason.
They also stated they always put 0.1 bar extra to what is recommend so they suggested I run on 2.8 bar. So that is what it was delievred on.
They had a high end pressure guage when they measured the pressure and it matched exactly what the TPM stated also, so seems the TPM is accurate for measurement.
Juat thought I'd give an update, as not sure if others are seeing the same issue.
jason4s
Australia
I contacted Porsche Australia about this, and they said to follow the target temperatures set by the TPM as "it provides the most accurate target based on the current vehicle settings and conditions."
I do notice that the target pressure changes as the car is driven and eventually settles. My guess is that the TPM adjusts the target pressures based on temperature as well. It's a little cold here at the moment and the system is telling me to set pressures slightly lower than the door sticker.
The pressures in the tyre should rise to close to what the door sticker recommends when the ambient temperatures heat up.
Stuart
Stuart
Amsterdam
Yes indeed, and sorry I never came back on this one seems there is a temperature sensor as well as pressure, so the TPM gives accurate pressure with regards to the current temperature, the pressure stated on the door shut is the pressure at ambient temperature of 20 °C. and the pressure will rise or fall by 0.1Bar for 10 °C change in temperature.
Hope this is clear and seems to be correct from what I have seen over the last months
