The charging battle btw Big Brother 800V and little Sister 12V
BigApple
BigApple
Andreas
NJ
Macan Turbo EV, E-tron, M3
That would be an outrageous price for a lead-acid battery. Especially without the “discount” that was mentioned.
I cant imagine it is lithium .. don't they need ~16.8V charging. It seems the charging Porsche provides in the car never goes over 15V.
BigApple
BigApple
Andreas
NJ
Here is the Power curve from the reader that is directly attached to the Battery
Pict 1 Shows when the battery is at a lower range. There is no indication that the cars Battery control module steps in to help when the charge goes low.
Electric Macan EV The charging battle btw Big Brother 800V and little Sister 12V 2025-03-22-21.58.46.669
as you see at around 10.30am the car dies.
When i got back to the car a day later i had to add a boost charger to the battery. (see pic 2)
Electric Macan EV The charging battle btw Big Brother 800V and little Sister 12V 2025-03-22-21.58.51.577
as you see at around 19.00 the boost kicked in and at around 20.30 i added a powered charger to the battery to charger it overnight.
I wonder what voltage an AGM battery needs to go below to be damaged/or no longer able to hold a charge the right way.
So from 20.30 to around 22.10 was the bulk charge. Then trickle charge kicked in. (Float)
All in all the car was not used (left alone) for 4 days and then battery died. given i now have a dashcam so there is an additional draw. But it is shocking that the car does not maintain its 12V battery. A simple programming algorithm should fix this i would imagine.
Note: the first time it died after 4 days i did not have a dashcam so no extra draw. And it died after around the same time. .
Solution: The Battery module should be set to charge the batterie when it reaches below a certain voltage.
And if that is such a earth shacking new idea than at least add a feature to the Remote app and let us have an on or off timer/toggle to charge the cars 12V battery. This should be easily doable as we already have that feature. The only difference would be that no extra power would be wasted to the heating/cooling system. It would allow the power where it needs to go for such function.
Currently for me to charge the battery remotely i have to run the cooling/heating and trigger it through a timer or manually. What a waste of energy just to charge the battery when you are away.
And if it wasn't for my Black Vue dashcam i wouldn't even know remotely what the SoC for my 12V is. Porsche does not give you such a readout in its app. Clearly not important to them.
To me : A dead car is a dead car no matter what battery died.
Scandinavian
Peter
Taycan T, Tesla M3P, Aston Martin DB9, Porsche 996 C4 Cab
If the Suncoast battery is the correct one, it has a capacity of 62 Ah. That is quite lot for an EV I think. There is no starter motor to pull. Just normal supply for lights, fans, pumps etc.
From you graph you seem to have a high draw on the battery constantly. That does not look normal. Could you not disconnect your dash cam to view and eliminate the draw from that? Do you have any graph earlier that the ones shown?
I think a visit to a competent Porsche service is required? There has to be something that is taking power all the time.
BigApple
BigApple
Andreas
NJ
They had my car for 1 week and determined that it was a bad battery. They went back and forth with porsche.
I am actually more concerned about that the car does not maintain the 12v battery. Draw or not.
I have Apex protect GPS which was provided by Porsche, complimentary. It monitors the 12v battery and you can set an alert to notify you if the voltage is below a certain range. By default is set at 11v, but you can change that to another number such as 12v. I’m away from home for a week and checked the battery voltage and it was 12.4v. I turned on Pre-climate and after a few minutes it was 14.6v. Just for that reason I may be inclined to renew the subscription once the complimentary period ends…
Scandinavian
Peter
Now I do not have a Macan yet, but have a Taycan. I have had 12 volt trouble there as well when leaving the car at the airport. It had drained the 12 volt battery while we were away on holiday. For a number of reasons the period got extended to more than 8 weeks and the battery was disconnected. That has not happened since though and we have left the car at home or other places for more than 6 weeks at a time and all has been fine. For Taycan it earlier was stated that the cycle count for charging the 12 volt battery when parked long term was set to max 8 cycles. Later software is said to have addressed this, but I am unsure how? Normally the 12 volt battery holds up very well considering the capacity in the Taycan is only about 40 Ah.
The Porsche design should most likely have been transferred in principle to the Macan and since there are so few reports of 12 volt problems, there likely is something strange in your car. How experienced is your dealer with Porsche EV’s?
BigApple
BigApple
Andreas
NJ
The first time they have determined that there was no parasitic draw then. But I wonder if they tested if there is no charge or maintaining the battery either within the car. Not sure if they tested that. Or there even is such a thing. Right now to get around this I run the heater 2-3 times a day to give the battery a boost to maintain it. What a waste of energy.
I had my car wrapped in PPF and ceramic coated recently, including the wheels, calipers, glass and leather interior. The whole process took nine days to allow drying etc.
The car was never driven during this time (the wheels were off) and the doors open and windows rolled down.
With the doors open the door and interior lights would have been on. I’m not sure if operational readyness was established, that would have depended on how far away the key was. I did check on the car several times per day to see which doors and windows were open.
I think this would have drained the 12V battery if the car didn’t recharge it from the High Voltage battery. The HV battery lost a couple of percent of charge during this time.
BigApple
BigApple
Andreas
NJ
I know the car gets charged when it is turned on. But I never tested what the minimum turn on is for it to provide power to the battery. Maybe worth Ido some more testing. This would ofcourse not fix normal day to day use.
BigApple
BigApple
Andreas
NJ
But normal day to day use also shouldn’t be a problem unless the 12V battery is defective.
Correct. But sometimes if I dont drive my car for more then 3 days I get punished because the car does not maintain the battery. I have to do it myself somehow.
BigApple
BigApple
Andreas
NJ
I'm still not convinced that your Blackvue doesn't play a part in this. I think we'd be seeing far more instances of problems if this affected every car.
It certainly plays a part in this. As it draws about 1/2 Ah. So yet it does the problem I have it that the car let’s the battery completely drain no matter what. I think it should step in when. A threshold is reached. My BlackVue has a voltage cutoff set to 12v. Yet the car is is still dead after 3-4 days.
Today I noticed that I lost remote app connection to the car. Could not do anything remotely through the porsche app until I walked up to the car and unlocked it. Suddenly the app worked again. It seemed like the car went completely offline until I manually open the doors. Does not make sense to me. And defeats the purpose of remote access.
SteveInKirkland
Stephen
2024 Porsche Macan 4 EV
Can someone track the 12volt battery voltage over time when the car is plugged into a charger but not recharging (because it is at the set SoC)?
If someone tells me the equipment to buy and how to safely do it, I'll do the leg work. Emphasis on safely.
BigApple
BigApple
Andreas
NJ
i got the ANCEL BM300 12V Battery tester
It can be directly connected to the 12 Battery poles. You can then monitor the draw or SoC of your 12V battery. It logs the data. And you can wirelessly retrieve it with the App.
I don't think the 12V gets a charge when the 800V is plugged in only. It charges the 12V only when you have it charge the 800V.
The fastest charge you can give your 12V battery remotely is when you press on the "Pre-Climate" on your App. This will unfortunately waste energy heating or cooling your cabin as well. But you get a 1h fast charge of around 14.6V for your 12V battery. Based on my tests this is the best way to charge your 12V unless you plug in external chargers of course.
To avoid too much additional energy loss. Set the temperature in a way where the heater/cooler has less to work up to.
I think if i remember right. When the DC charger is used and charges the 800V portion of your Car at home it sends about 13.V to the 12VBattery so that is a little less but on a few hours of charge it may just work out as well. Anything helps.
The pre-defined scheduled Heating/Cooling you can set does not provide enough charge to my battery to maintain it for my 3Ch dashcam. I wish it would. So i would not have to even think about manually charging/pre-climate my car at least once a day.
I wish Porsche would add a option to the App to condition the 12V battery by doing the same thing the Heating/Cooling does, just not sent power to the AC or heater and thus not waste power from the 800V for no reason. OfCourse The best thing would be for the car to do it all by itself when it reaches like 12V or below.
But clearly this is too complex and too much to ask for with today's technology.
To my Porsche neighbors in Stuttgart: Ich war immer stolz auf deutsche wert arbeit. Aber hier muss ich sagen habt ihr echt versagt. Das sollte doch so einfach sein heut zu tage. $130K und ich muss mir gedanken machen wie ich das nun selber auf die reihe bringe weil es von euch nicht durchdacht wurde. Oder noch schlimmer es war euch egal. Das letztere wird die zukunft zeigen. Gruesse von Bad Cannstatt.
