Uneven rear tyre wear
stu040688
Stu
Pembrokeshire
Hi all,
just had my Macan 4S back from having a bad rattle fixed behind the passenger side dash and was handed a vehicle inspection report saying both rear tyres were wearing unevenly with only 4 mm tread on the outside edges. Car was new a year ago and has only 6500 miles on the clock. I queried it and was told its how the car is set up and a number of Macans were showing this. I’ve asked for this in writing but nothing yet. Anybody suffering this uneven wear on the rears?
Do you have an air suspension and drive in lower/low modes?
This may be due to alignment problems caused by the air suspension. The alignment seems fine in normal mode but when you lower it everything goes off the charts. This is yet another issue on some cars it seems, I'm set for another attempt to fix it this month.
Don't know if thats your issue but it may be of some help if your alignment seems fine but tires are uneven.
stu040688
Stu
Pembrokeshire
Hi chaps,
got air suspension and have only driven my car in “normal” mode. Tyre pressures are as recommended and I wouldn’t be cynical if only one rear was a problem….but it’s both rears! Both down to 4mm on the outer edges compared to 7mm on the inside edges.
Fluff
I'd just get the alignment checked by a good tyre place, and crack on. I was getting about 12000 miles per set in my I-pace, I'm not expecting anything better, its a 2 ton sports SUV, and I'm not Miss Daisy.
stu040688
Stu
Pembrokeshire
Yeah….but it’s not the tyre wear that bothers me mate, it’s if it’s set up badly and is this common. 2 ton suvs shouldn’t be riding on the tyre edges.
Fluff
I'll let you know in 5000 miles...
aks
Tony
Hertfordshire, UK
BMW F90 M5, Macan 4S MY26
What size wheels do you have?
This is a 'common' problem on BMW X5 and 22" wheels (rear 315/30 R22) according to Kwik-Fit, as, they say, "due to the setup and the tyres being extremely wide". Fundamentally not an alignment issue, but "expected". I've no idea if they were talking total rubbish!
Alan79
Alan
Uk
Range Rover
Hi all,
Hi all,
Yep. I am having uneven tyre wear. Down to 3mm on rear outer 5 on inner. Also. Tyres cracking bady. Bridgestone 21inch. 4s
TS23
BMW G82 M4
What are the OEM tyre options? I went for 22 Spyders but didn't opt for Performance Tyres and got P Zero’s
