Battery temperature
DHS
Maryland
I'm a new EV owner (Macan 4) and ignorant of the significance of my battery's temperature. Why do I care? Why is it prominently displayed? What is the ideal temperature? What can I do to change it?
KJohn3333
K
Jaguar IPace
Good question I’m getting my new Macan in January and would like more information on this. Coming from an all electric Jaguar IPace the battery temperature is something I don’t ever recall seeing. I’d guess the temperature is relative to range and charging times. A cold battery is less efficient and I think I’m correct in saying that conditioning the battery with it plugged in before driving will improve the range.
It would be interesting to know just how long driving or conditioning before a battery reaches optimum temperature from cold, starting from different battery and air temperatures.
all of this shown on the gauge/cluster
the right temperature is best for power and charging. I'll try to find the image, but apparently it shows on the perimeter of the gauge, what the ideal temperature for operation is ..or at least, how far from that temperature you currently are
iirc from a video (i don't recall which), it was explained that the dial shows a marker for the current temp (the lil arrow)
and a range for the ideal temp (the grey bar above it the arrow)
Electric Macan EV Battery temperature 1733110101970-q9
CDW
X5 3.0D, X3 30e, Macan 4
I was wondering about this myself, should it not be also higher (around 30 deg. c) for normal driving?
For example this morning mine was 4 deg. and the only time I see it higher 28 deg. (even though cold outside) was when it was pre-conditioning it for the next DC charging station.
Same results. I can not say it's correct or not since this kind of meter wasn't on my Tesla.
HV battery temperature is one of the most important vitals including 12V battery voltage. I am going to defer to other more scientifically inclined to comment on ideal temperature with my understanding the car controls it at all times. My use for it is to pre-condition it for optimal charging as shown below.
Electric Macan EV Battery temperature Batt Tem
Duke95
Chicago, il
The issue is whether using energy to heat the battery uses more energy than the loss of efficiency of a cold battery when driving. And the answer is ..probably, it depends on how cold, and how far one will drive with the cold battery. I started a post a few days ago on my first freezing road trip and the car does not seem to favor using energy to heat the battery up too much...stayed in the 40 degrees F range for quite a long time. Preconditioning the battery also takes a long time with a battery that is very cold.
nulled
Portugal
What I read in the press release is that it doesn’t need preconditioning to hit high speeds of charging. And indeed when I plug it in a 150kwh charger, it hits the speed in 1min after plugging without any preconditioning.
@nulled, the graph that I posted from Macan EV documentation showing optimal conditions to reach the maximum charge speeds if desired with battery temperatures needed are pretty low (a good thing). The battery tech in the latest Taycan and Macan EV improved significantly to allow for fast charging at much lower temperatures than before, with main benefit of less or no pre-conditioning energy burn.
For example, original Taycan requires the battery temp to be between 85F and 95F to achieve maximum peak of 270kW to complete a charge from 5% to 80% in 22.5 minutes, now the refresh Taycan can reach 300kW peak charge speeds at a battery temp of 59F to complete a charge from 10% to 80% in 18 minutes vs. 37 minutes it would have taken the original Taycan to do the same.
