Range / consumption of 2025 Macan EV ?
10% is much normally it’s around 5 … so I calculate with 90kwh usable …
Macan EV batteries are of a different chemistry so hopefully that means less loss of SoH. However, this is my data for the 2023 Taycan measuring SoH every 1k miles and doing a checksum check on the back using battery energy data reported, showing steep loss of capacity during the first 10k miles.
Electric Macan EV Range / consumption of 2025 Macan EV ? 1735226396456-nl
CarWow recently completed a range test. The Macan finished 2nd of 6. I would love to see this test identically repeated during summer weather.
I see 5% difference with my iX Summer versus winter … so one can only compare SOH when the battery has been at the same average temp for some weeks … I f that is the case it’s a rather steep drop
This is both interesting and a bit distressing. What are your charging habits (meaning: AC vs DC charging, percentage you charge up to, percentage you run down to, is the car garaged, how often do you charge, etc.) I realize it's probably hard to give either a general or detailed answer to some of those questions, but maybe you could provide an an overview. Thanks!
I see 10% less range in my iX during the winter, e.g., different drivers, wheel size, climate, and perhaps my A/S Michelins are different than Yves”.
SoH is not SoC. SoH has to do with battery degradation over time so it will impact range no matter of the season or temperature.
My data above is consistent with other Taycan owners, so it is expected. Always garaged in insulated garage with the most gentle charging protocol known to me based on data.
The question is will Macan EV see same degradation behavior.
With the app eFlow I measure lower SOH in winter then in summer, the reason is quite simpel, with lower temps the battery has lower capacity and there is no way that I know of that this can be taken into account …
I think I even noticed this with the BMW data itself, you can get via the portal all data of your car … it reports vastly different numbers in winter versus summer …
I do know that SOH is not only capacity, but I definitely see a difference in summer vs winter in the App I was below community average in winter and above in summer ?‍♂
You also see this in your graph … the battery cannot heal itself a gain back capacity / SOH, these processes are irreversible …
PS I do know the difference between SOC en SOH ;-)
Very good points and apologies for SoH vs SoC. I think of a SoH or SoC as measurable values but Range is variable from summer to winter, so my understanding that SoC will not be different under different ambient temperatures in the cells but I will measure and compare voltages to see if that is the case.
cottony
United-States
tesla
How’s this for day 1 efficiency haha
granted I spent a ton of time just sitting in the car going through the settings mixed in with some launches lol
Electric Macan EV Range / consumption of 2025 Macan EV ? 1735459328528-ak
