Tilt mirrors down when reversing
I did see your guidance. It did not help me. You posted to move the mirror down and save the setting. On my vehicle, with the mirror moved fully outward, as I have it set for driving, I wasn’t able to tilt it down at all (go ahead, try it). I then realized it would tilt down if I first moved it inward. I then saved the setting and it works fine. I’m not sure what is extreme about that, and it certainly was necessary to get it operational.
i might have been too detailed in the description, but I was just trying to be clear.
The issue seems to be that many cars are delivered with the mirror set in a total crazy position from the get go.
From your regular passenger mirror setting, the power on, R drive mode, adjust all the way to what you need, save to key should just work.
I've done this procedure for many Porsches since 2006 and they all work in the same way.
Odd to find one that doesn't.
Either way you have found a method.
SimonEV
Simon
United Kingdom
The passenger mirror tilts down in reverse and is programmed by first selecting R and then adjusting for the tilted position that is saved for next time.
When you reverse there are several situations: back to an obstacle e.g., a garage door or back next to the curb e.g. to avoid curbing a wheel.
Both cases are different because only one requires the manipulation downwards. Do you control this by selecting the buttons that select the left/right mirror as a shift/don’t shift down?
Go4it
Paul
Cambs
Macan4S
Yes I also got it working after a bit of tinkering!
Two observations regarding the door mirrors....
1) It looks like dipping only occurs on the passenger mirror, I.e. not the drivers mirror. This does seem strange to me.
2) Are the mirrors heated? Doesn't seem to have a heat on/off button or option in set up. If not then this too is very strange, especially on a "premium" vehicle. ?
Only intended to be the kerbside (passenger) on RHD or LHD vehicles - same for all Porsches (and many other brands). Technically both could but I guess it's a deliberate act to not dip the driver's due to the likelihood of approaching traffic in most situations.
Mirrors are heated - only when you turn on the rear demister (no separate button for the mirrors).
never seen a car that had a specific mirror heat button personally...
Go4it
Paul
Cambs
Macan4S
Thanks. I'll give it a go.
SimonEV
Simon
United Kingdom
The Manual does describes the setting of the Passenger Mirror when R (reverse) is selected.
However, the Manual could have explicitly said that there are three saved positions that can be recalled.
So that when reversing, you can switch between normal and dipped using the two buttons. A “hidden” benefit for those not already familiar with its uses.
There are cars. This is a thing on Honda and Acura cars. 2008 Acura TSX came with dedicated heated mirror button. Porsche does not have a dedicated button as it is tied to the Rear Defroster button as @Go4it mentioned, and always has been that way.
Acura Heated Mirror button.
Electric Macan EV Tilt mirrors down when reversing 1737582266684-kg
Electric Macan EV Tilt mirrors down when reversing 1737581975835-u
The memory buttons are for all settings and not just the mirror(s) - I guess they assumed folk would use the memory buttons in addition to the 2 keys to recall specific use cases.
My guess is most people don't use the memory buttons at all and rely on the key but when sharing the key it is then wise to use the memory buttons to recall an alternative set of settings for that user.
SimonEV
Simon
United Kingdom
The three saved positions, in this context of using Mirrors, relate to the saving/recall of the Mirror Settings which are Passenger Mirror (normal), Passenger Mirror (Alternative e.g., "dipped") and Driver Mirror (normal).
This means that when reversing, the two Mirror Buttons can be used to switch between two saved settings of the Passenger Mirror.
My issue with the Manual is that it isn't explicit enough to reveal this Passenger Mirror "feature" - that is quite useful.
I understand what you would use them for but lost as to why when selecting 'R' and the dipped setting already programmed gives your the passenger option regardless. You may wish to dip both driver and passenger so that might be a useful combination.
Choice is yours at the end of the day.
TypeMRT
Maurice
Washington, DC
Porsche Macan Turbo Electric
How can I turn the feature off and saved to the memory and profile? I tried to match the normal and reverse mirror positions, but there’s still a bit of repositioning because I couldn’t get it exactly the same.
Uncheck the box in the settings / car options and then save to key / memory.
