Preconditioning Battery
Minternico
Ambler, PA
Macan EV 4
My service manager advised me now into month 5 that the car does not precondition the battery to maximize the charge speed while navigating to EA chargers. Has anyone succeeded in this weather by having the battery at the maximum temperature to achieve fast charging?
Minternico
Ambler, PA
Macan EV 4
Yeah I set the destination up and see my battery go from 2c to 20c at destination. It works fine just like the Taycan on that front.
I would appreciate the assistance on how to, thank you!
Doggo
Doggo
NYC
Turbo
add a destination close to the charger, and then add a battery stop to kick off the preheat.
You need to select a fast charger as destination, not an address close buy, it needs to be the charger, also it takes a long time, I had my battery at 4C and it took like 40 minutes of driving to get it up to a descent temp, that was not even the optimum
tonyadduci
tony
chicago, il
porsche macan ev turbo
I agree, this needs a lot of refinement/work. Setting the destination of a charger doesn't make it clear that the battery heating process is underway. You have to just stare at the battery temp guage. Why can't there just be a button that says preheat battery to X or for X time?
The OP is asking for a step by step.
There are 2 ways to do it, as others are suggesting.
Observe battery temp going up if preconditioning of the battery is working. You need to be in the optimal conditions below to get the fastest charging possible when you get to the charger.
Electric Macan EV Preconditioning Battery 1737667701409-xo
1: Set Charger as Destination from the Charger tile of the Nav system
Electric Macan EV Preconditioning Battery 1737667489755-hc
2. Set Destination as Favorite (star tile) then 3-dots next to is to open a pop up to select NearBy Charger search and then set it as a Stop over.
Just make it so that in the Bat display you see a heating symbol and give us a manual pre heating button in car and in the app just like in the iX … even ABRP / Maps can trigger the pre conditioning button if it figures out that the destination in Apple Maps is out of destination, I just need to confirm the pre heating ?
