- First Name
- peter
- Dec 23, 2024
- Austria
- Macan Turbo EV, porsche 911 limited edition, GMC Sierra Grande1971, Smart Brabus
In some threads there is talk of “preconditioning” of the battery. This is certainly important in connection which navigation can be used (e.g. Waze). It is generally assumed that this is why you should use the Porsche navigation system, so that the battery is “prepared” for charging.
There is no possibility to start this “preconditioning” process manually. The car itself ensures that the battery is at operating temperature. Many people apparently believe that the battery should be “warmed up” especially at cold temperatures. The opposite seems to be the case. The battery should not be too hot, but it can be assumed that the system itself will take care of this.
Porsche Manual:
High-voltage battery care
If the battery reaches a temperature that is too high due to external influences, the battery is conditioned (cooled). Depending on the service life and battery charge, the temperature range for conditioning is reduced.
To reduce aging and wear of the high-voltage battery, observe the following measures:
Porsche Manual:
- Charge the vehicle at temperatures between approx. –4 °F and approx. +86 °F.
- Avoid exposing the vehicle to temperatures above 86 °F for long periods of time, e.g. by parking it in direct sunlight.
- At ambient temperatures above 86 °F when parked: Connect the vehicle to the power supply after use. Charge the high-voltage battery with alternating current (AC) to a maximum battery charge of 80%.
- Especially before long journeys: Initiate the charging process via the Charging Planner and use the Departure function to charge with alternating current (AC).
- For daily use of the vehicle without long-distance journeys, set the battery charge to approximately 80%.
- If necessary, set the battery charge to 100% before long-distance trips.
- If the battery charge is below 5%, charge the high-voltage battery.
