Lock / Unlock through app (latest version 14.0.1) misleading response.
BigApple
Andreas
NJ
Macan Turbo EV, E-tron, M3
I just tested to unlock my car remotely through the app. The car unlocked just fine, but the app says that this function is currently not available.
And it makes you believe that the car is still locked or unlocked. Yet it worked as intended. You may leave it alone not knowing the car is actually open. Even though the app shows as locked.
Maybe someone else can verify this behavior. I get the feeling the communication is one way and it seems to not send back the confirmation that its locked/unlocked.
jh6284
Jamie
Mustang Mach E and ordered Porsche Macan 4S
I am experiencing the exact same behaviour.
BigApple
BigApple
Andreas
NJ
hmm are you also on the latest version of the App ? 14.0.1 ?
i wonder if that is because of the new version or an issue beyond that
jh6284
Jamie
Yes I'm on the current Version 14.0.1. Hoping they do an update on the app soon to correct this. Lock/Unlock should be fairly basic stuff!
LivingTheDream
Thomas
Greater Boston
Macan 4S 718 Boxster
There's something amiss with that version number you're seeing. I have the same number within the app (at the bottom of the "Account" tab): 14.25.3 build 382. However, if you go into the App Store, it indicates that the latest rev (which I have installed) is 14.0.1.
Not sure what's up here.
jh6284
Jamie
In the app itself under the Account tab it shows v14.25.3 build 382 but the version in the Apple app store is 14.0.1
Electric Macan EV Lock / Unlock through app (latest version 14.0.1) misleading response. IMG_4953
Electric Macan EV Lock / Unlock through app (latest version 14.0.1) misleading response. IMG_4952
if mine does that, i just run the function again until i get the confirmation
SteveInKirkland
Stephen
2024 Porsche Macan 4 EV
I have v14.25.3 build 382 iOS My Porsche app and I get the same behavior: the app reports that it can't unlock the car; the car is unlocked; and then, after some time, the car re-locks itself (probably because of comfort access settings and the inability to see a key).
henrus
Henry
Bay Area
I've seen that error before (using a prior version of the app, can't recall which one. It seems to happen intermittently because the next day, it worked fine. I count it as one of (many) software issues that the Macan EV/Porsche are having (Plug and Charge problems, clock not setting problem, etc.)
jh6284
Jamie
I ended up doing a factory reset and it solved this issue. Lock and unlock now working properly in the app. It also fixed my plug and charge issue as well as allowing the Automatic Date and time. Very happy the reset solved all of these minor but annoying issues. All is good and I’m loving my 4S ?
I have recently experienced that same issue with the same version of the app.
The car will automatically relock after 45 seconds if no door,trunk or hood is opened.
