Home Assistant is now available as a Porsche App
SteveInKirkland
Stephen
2024 Porsche Macan 4 EV
I installed it today but haven't finished configuration yet. It looks like I can use this to activate my garage door openers automatically, but I'll know more as I work through testing.
TurboSpain
Spain
That's right, it's also available in Europe. I discovered it yesterday, and it's great news. It was announced that Home Assistant would be included in the PCM from the car's launch, but it hasn't arrived until now.
Electric Macan EV Home Assistant is now available as a Porsche App 1751350926812-ac
SteveInKirkland
Stephen
In the passenger display or the center display, select "Apps" from the list of options and then search for the Home Assistant app.
You need to have a running instance of Home Assistant somewhere to connect to. I'm configuring a user specifically for the car, but I haven't had time to complete the full setup yet.
ferik
Erik
Boston, MA
991.2 GT3 Touring, 1985 911 3.2
I might be stating the obvious but Home Assistant requires a whole lof of things to get going, not just the CarPlay or Porsche App. It requires a server to run it, remote access, installing integrations to work with your home automation items, etc. It's well worth it if you can do it but I wanted to manage expectations that it's a whole ecosystem you have to set up.
SteveInKirkland
Stephen
Yes, the Porsche app "needs?" integrated WireGuard.
I pay NabuCasa for remote access to give them some money, but it does come in handy.
My garage doors are integrated with home assistant at home and they work with location identification on my iPhone. So, it should be "easy" (for me) to check if the car can take over for the phone user. My brother's Rivian seems to have this better integrated, but we'll see how close I can get the experience for my wife.
TurboSpain
Spain
Nabucasa is the best option. Simple and secure. It also financially supports the Home Assistant project.
For Home Assistant users, in case you weren't familiar with it, there's a Porsche Connect integration via HACS. You get all the app data available in HA.
https://github.com/CJNE/ha-porscheconnect
I also have my entire house controlled by HA, including the garage doors and security system. It's very useful to access all of this through PCM. So far, I've used HA on Android Auto; now I'll try the native PCM app.
HA is very difficult for non tech folks to set up and make work. Been there, done that. Plenty of hidden charges and land mines. But this is great for those already with the infrastructure.
For others, there are easier ways to open garage doors and turn on lights as you approach. My garage doors open for me automatically via as I approach as long as I'm carrying my iPhone. The driveway lights also tun on when its dark.
P11VLM
Paul
Porsche & BMW
Is anyone using this in anger? I’ve setup a server today and got it up and running but am stuck as to how i create more widgets? I want a widget for Climate at home.
Electric Macan EV Home Assistant is now available as a Porsche App IMG_6007
TurboSpain
Spain
When you are parked simply go to Settings > Companion app > Android Auto favorites (or Driving favorites) and select the entities you wish to view. Once you have added favorites the next time you start the Home Assistant app in the vehicle you will be shown your favorite entities.
https://companion.home-assistant.io/docs/android-auto/
Obviously, the air conditioning entitie must have been previously configured in Home Assistant.
P11VLM
Paul
Porsche & BMW
thanks for that, i did a test with a light which worked, but for some reason the heating devices, dont appear in the favourites. They werent added as a straight integration, I add to add to the yaml config. They appear in the full fat view as controllable items, but not favs or view i posted above.
The heating devices are the circle items, one on the right that adjust the temp.
Electric Macan EV Home Assistant is now available as a Porsche App IMG_6006
P11VLM
Paul
Porsche & BMW
Ive asked my resident Ai and she advsied, The native app interface does not support climate entities (like climate.family_room_thermostat) at the moment. This is a limitation of Porsche's integration, not your Home Assistant setup.
I can create some custom scripts that may work so i’ll try that??
P11VLM
Paul
Porsche & BMW
Yeah writing a script worked. I only use the climate devices to turn heat on in specific rooms when coming home, so a few scripts to control specific rooms is all thats needed.
Electric Macan EV Home Assistant is now available as a Porsche App IMG_6011
Electric Macan EV Home Assistant is now available as a Porsche App IMG_6010
mako
Finland
Macan 4S 2025
The Home Assistant app in my car has disappeared and I can't find it anymore in App gallery! Do you still have HA available?
