- First Name
- David
- Nov 17, 2024
- New Hampshire
- 2024 Macan 4 (Volvo XC60 PHEV, Subaru Forester ICE)
I know I've seen this somewhere, but a search only turned up one post about this happening to someone else.
I've been charging typically at 9.4 kW on my ChargePoint EVSE for a year. Usually I charge to 75% or 80%. I was going on a longer trip this morning, so I decided to charge to 85%. I have battery preservation mode on. The car was actually showing 81%, and when I raised the limit to 85% (besides getting the charge preservation warning) it started charging only at 3.9 kW and stayed there all the way to 85%.
I unplugged, took my trip, and came home at about 35%. I shut off charge preservation (just in case), set the limit to 75%, and now it's still charging at 3.9 kW. I don't have easy access to an alternative EVSE to check that out. The car was closed and locked for a few minutes twice during this trip.
The one post I found with this problem, the response, among other things, was to disconnect the 12-volt for a few minutes. I did not find a post saying whether this works or not.
So, 3 questions:
1. For anyone who has had this problem, if they tried disconnecting the 12-volt, did that work?
2. If you do disconnect the 12-volt, what settings, if any, do you lose?
3. Does anyone have an alternate solution besides traveling to my dealer an hour and a half away?
So, 3 questions:
