Battery cells reset/rebalancing after erratic SoC readings
Also there is a lot of garbage data or perhaps incorrect formatting in car scanner from what I can see. It makes me not really trust the data that looks reasonable when so much of the data looks bad.
the highest voltage being 0. anything seems completely wrong, for example. My house Li battery backup cells are usually in the 3-4v range even when completely discharged.
Jetced
Cedric
Bratislava
Macan EV turbo 09/24
@Fly4ever was your case also paired with slow charge speeds a HPC chargers? Currently I only get about 120kW at 400kW stations. And my range is incredibly bad. Last night I git home at 5% and 13km left. 2h later it showed 10% and 27km.
Wasn’t able to charge full as I had to leave in the morning. Will try to get very low again next week
@Jetced,no my charging speed at ultra fast chargers was (and still is) fine,my only problem was the SoC % erratic behaviour.Now,almost 700Km later and many charging sessions at both slow,fast and ultra fast chargers everything is still o.k. and SoC shows me exactly what it should according to what the kWh/100Km indicator shows and what the charger reports I received as well after a charging session is completed.I calculated the SoC to be approx 90-95% accurate both during driving and charging as well.
Concerning range I'm getting around 420-430Km of highway driving with the car heavily loaded and OAT @15° C and driving speed around 115-130Km/hour - 97Km/hour average (20' snow tyres and forged light wheels).
Philip_1
Filippos
VW T-rox / GLC 300
After one year and due to change of user in Porsche center I had to calibrate the battery.It worked well.
Before and After Calibration
Electric Macan EV Battery cells reset/rebalancing after erratic SoC readings 20260318_065612
Electric Macan EV Battery cells reset/rebalancing after erratic SoC readings 20260313_122850
Jetced
Cedric
Bratislava
How many cycles did you do?
Philip_1
Filippos
VW T-rox / GLC 300
Difficult to read everything here, I will make as simple as I can to explain my procedure.
1: dropped to 1%, after about 8 hours resting ,BOOM became 23%!
2: dropped to 4% after about 8 hours resting ,became 14%.
3: dropped to 4% after about 8 hours resting , became 6%.
4: Charged to 100% and keep it plugged for few hours. During charging the time of completion changed 3 times it self, and every time was adding more hours to reach the target of 100%. For example reached 90% and after a while became 73% again, finally 100% and unplugged.
5: After few minutes resting dropped again to 85% and the range became normal.
6: I added estimated due to loses: 3.6KWh x 22hours = 75.6 kWh + 8kwh was already on start= 83.6kwh + 15% missing from totally battery level of my car now, I am very near to the Total battery capacity.
Equivalent to ~540 km at 100% (Display range!)
I hope I helped.
(All numbers are based on rough estimations due to loses etc).
de0xyrib0se
Sofia, Bulgaria
Note that the Battery Management System will rebalance the cells at both low (<20%) and high charge rates (100%). I'm surprised there isn't an official statement or at least a paragraph in the manual about this. You just have to be very careful with ambient temps when going the low route.
Mercedes for example recommends leaving the car at <20% every 6 months with ambient temps >= 10C, so that the BMS can rebalance the cells.
Philip_1
Filippos
VW T-rox / GLC 300
I never had problem so far until Porsche Center changed user to "guest"
They say that BMS will make the calibration as you mentioned, but I am not sure how effective is doing it with this software..I charged to 100% and the results was as per my photo above before calibration.
Later I found this procedure from Taycan forums and it worked at once..Range came back and actual amount of KWh near to the useable capacity as per specification enter the battery..
Before this...For first time, I was 95% and the navigation was saying arrival range 50% for 1.5km distance!!
Not planning to do this all the time..but now i am back on track as I was for a year now, but generally... PORSCHE NEEDS TO WORK SERIOUSLY IN THIS SOFTWARE AND MOREOVER TO TRAIN UNWILLING DEALERS TO DEAL WITH ISSUES AS THEY ARE OBLIGATED.
de0xyrib0se
Sofia, Bulgaria
The irony is the people that represent the brand in front of customers, the dealers, are not Porsche. Most of the time trying to get you in the shop for service hours.
Finding a good dealer is more important than finding a car unfortunately.
Neither are the people writing the software, VW...
Philip_1
Filippos
VW T-rox / GLC 300
It is true by 100%...... You go there and they JUST looking your car.... and then they say it's okay! You take it back and then you will find that they did nothing..
Don't get me wrong the car is impressive by all means..But dealers and service stations proven to be incompetent.... Strange but a fact..
I own also one T-Roc - VW and for 5 years ZERO issues... I understand different technology but cost is also five times less..
de0xyrib0se
Sofia, Bulgaria
If you find a good dealer that cares, cherish it...
BMW dealer tried to convince me I damaged my own car after they put two dents into it during an oil change! Same crap all over the place.
Philip_1
Filippos
VW T-rox / GLC 300
Wow.. that's bad..So far the most positive experience I had is with Mercedes..ln Greece, not sure for other countries..
Sideline
1: dropped to 1%, after about 8 hours BOOM 23%!
2: dropped to 4% after about 8 hours 14%
3: dropped to 4% after about 8 hours 6%
4: Charged to 100% without unplug it the car during charging changed 3 times the time of completion, and it adding more hours to reach the target of 100%. For example reached 90% and after a while became 73% again, finally 100% unplugged.
5: After few minutes dropped again to 85% and the range became normal.
I hope I helped.
Sorry to bother you but can you clarify your specific procedure? After you dropped to 1% (and 8 hours later it jumped to 23%), did you run down the battery again to get it to 4% (which then led to 14% after 8 hours)? Or did you do a full charge to 100% after each cycle of dropping to low SoC?
Philip_1
Filippos
VW T-rox / GLC 300
No bothering at all!
Yes correct, In all steps I let the car rest for almost 8 hrs,(somewhere in the net I saw 6,5 is enough but I let it 8), then I drain further until the last step 3.( Small % changed from the level left the car until next morning). So balanced achieved in low level.
(It looks like in lower levels it is balancing the cells and that is why u may see increased % after couple of hours.
Later I went all they way up to 100%, as the car this way learning the true capacity of the battery, the top end.
I kept it connected even after reaching the 100% for few hours, (Step 4) The high level calibration completed once I reached the Real 100%.. not only by the Soc readings but also by the actual kWh that I load in the battery.(Step 5).
Sideline
Thanks. After you reached 100%, did you leave the charger connected to the car for another 8 hours? And did you then disconnect and let the car sit locked and without app activity for a further period?
