Maybe I should create a new thread
Has anyone else experienced this?
There are already threads here from others with the same symptoms. This one's the shortest, with some actionable steps you can take to try to 'fix' it without a dealer (although reporting to the dealer should be done to get Porsche visibility on this, and their cell reset process is better if you can get them to do it)
https://www.macanevowners.com/forum...rebalancing-after-erratic-soc-readings.25084/
FrostyFjord
Ilkka
Finland
tesla m3
Thanks! I've missed those discussions. I definitely have the same symptoms as others there.
pm4s
In an ideal world they would roll-back the OBC firmware to the previous version (as that worked fine) and try again. Should not take more than a day.
Posted the above back in February, took Porsche more than a day (actually several months) but they finally woke up and started doing it, Macan can home charge (proud achievement / laughs in any other EV).
Anyway enough blabbing, download the attached bulletin if you want to read it from the horse's mouth.
Thanks for posting Porsche’s bulletin on the charging problem fix.
I think I’m still going to hold off on the VR28.11 update (Workshop Campaign WSD0) until a revised version is available. Mostly because there is no guarantee that my car is not going to turn out to be one of the affected ones, and I don’t wish to deal with the hassle even if there is a temporary fix.
One of the statements on the bulletin is a bit concerning: “Damage caused by inadequate voltage during programming is not a warrantable defect.”
I suppose the dealership will have to pay for the replacement of the damaged control unit then. However, what if the problem (control unit malfunction) appears afterwards, but likely as a result of a recent dealership performed software update, does that mean that it becomes unclear who pays for its replacement?
Flying4Fun
I had a long post about charging issues, that I had to delete, and report this....
I just got my car back from service after having 6 weeks of work done, and AC charging would not work. I assumed it was the same issue as everyone was having here, and that the software update they did in Nov 2025 for me, had to be reverted like others have done - they replaced my assist module, and reflashed the car - so the jumping to conclusion was an easy bridge to walk across.
I got a loaner car by a small miracle, another EV. After running the battery down, had to charge on by AC AUTEL charger, but had the exact same issue.
Called AUTEL, they had me do some trouble shooting, such as remove the car profile, and reboot the charger and the car started charging! tried a few times, and everything was back to normal.
In discussions, AUTEL said they upgraded the firmware from 1.36 to 1.38 a few weeks ago (I was away on vacation so first chance to charge it was this weekend - and they have had reports of this issue with this firmware, and think over the next few days a new update will come out to correct it.
The work around seems to be remove the car profile, and reboot. But he did say if it happens again to factory default, and re initialize the charge without adding a car profile and that should allow it to work until they update the firmware
The at issue firmware is:
Charge Control Module 1.38.00 (1.36.00 was the prev version working just fine - I have auto updated enabled)
Power Control Module 1.20.00 (don't know the prev version or if it changed, but the issue seems to be in charge control module)
The local dealer was about to downgrade the software as per what everyone on this thread was recently doing, but that no longer seems required.
lukine
lukine
Inez
Thank you for posting this bulletin notice from Porsche. How did you get a hand on this?
I just finally got my car downgraded and have confirmed the update reversal has fixed my charging issue.
Insane how it took Porsche engineers 4+ months to come up with this “update” 🤦🏻‍♀️ Why couldn’t they have done that as a temporary fix sooner? 🤯
I had the same concern as you when I read that line. I am especially concerned because the software downgrade originally would not take on my vehicle multiple times. Dealership took over a week to get it working with the help of Germany as well. But I guess as long as your car is still under warranty, the dealership will have to cover for it.
loudsnorelax
United States
BMW X7
This thread seems to have died off. I'm wondering how many owners are still having home charging issues?
My closest dealer is not attempting to do any fixes because they keep bricking a component on the car when they follow the procedure.
I have an appointment later this month with the dealer I purchased the car from. They are completely unaware of the issue and are willing to give me a loaner and fix the car no matter what it takes.
I still cannot charge at home, nor at any other level 1 or level 2 charger I come across.
Flying4Fun
I started having issues a few weeks ago. I was aware of this thread and was not having issues and my software upgrade was original done in Nov 2025. I had to have the assist hardware replaced, and a reprogram, that reprogram broke the charge. I had an Autel issue come up at the same time, so they didn't downgrade as per procedure. Was fine for a bit, and then this week it started up again.
I'm going in Friday to get the procedure done, hopefully it works.
I have been able to get it to charge about 50% of the time by plugging it in and removing it about 80 times (not hyperbole, I sit there sometimes for 1.5 hours doing this before it works when desperate for a charge, I live over an hour round trip plus charger time from the Super Charger) and if I catch the feeder voltage at just the right time, it will work and continue to charge the car.
Hopefully the software procedure works for me as well as it seems to have for the others.
I was planning on reporting back what happens after a week. The weather here was a little funny, huge winds etc, the shift from cold to warm, sometimes going from minus 10c to +18c in the same 1 or two days. I have a line conditioner on some AV gear, and was watching the voltage swing 4v and 5v on the 120v side (118 to 123) so I assume this is why the EVSE and Macan don't sync up and charge except for the narrow window when my game of roulette starts the charge inside the right voltage window.
someTimesJoe
Joseph
Tri Valley, Ca
Taycan CT 4S, Macan EV 4S
I still have the issue as I haven’t been able to bring it back in for service. Service is about 3-4 weeks out if I wanted a loaner, too.
Other issues have come up where I’ve lost audio and it’s only on the drivers side door.
I’ve been dealing with the charging issue but for sure needs to be fixed soon as it’s annoying.
