- Dec 7, 2024
- Los Angeles, California
- 2025 Macan EV Turbo
He’s coming from a Tesla Model X Plaid, the Macan EV Base will feel very slow in comparison.
Oh, I wasn’t aware that Heated Window is a cell phone blocker. Anyone have personal experience with this?I would absolutely add the AR HUD. Totally worth it.
If you have the money and don't want to compromise, get the Burmester, but if you can put the money towards a higher level motor, I'd go for that instead of the Burmester and stick with the Bose.
Heated window is more of a cell phone blocker than noise/thermal insulation. If you park outside and live in Northern climates, you'll probably still want it. If you're a garage parker or not-much-snow climate dweller, maybe forgo the heated front window.
Sport Chrono is good; I wish I had gotten it for the extra drive mode.
This is trueHe’s coming from a Tesla Model X Plaid, the Macan EV Base will feel very slow in comparison.
I believe you are incorrect. One can see which wheels are operating and which are regenerating at any time by entering "car" then selecting "trip" on the center screen which shows you how your car power is in operation. The front wheels are definitely not being used as much as you think.That is just wrong.
The Macan EV uses permanent magnet motors, and unless they are receiving current, they act as generators and are producing a braking force. Most of the braking force always comes from the front axle, therefore in a 4/4S/GTS/Turbo the front motor is regenerating more than the rear motor.
Unless you are braking, the front motor in your 4S is always receiving some current.
No current is sent to the front motor unless needed, the vehicle is pushed by the rear motor and since no clutch as the front wheels turn so does the front motor, it spins freely. Obviously there are some minor friction losses which is why RWD Macan is the most efficient.The motor for the front axle must always receive current while driving, since it is a permanent magnet motor and there is no clutch to disconnect the motor from the axle.
Most of the current may be going to the rear motor, but if the front motor doesn’t receive power, it will be braking/regenerating.
This did cross my mind, but I’m okay with this combination. Thanks for looking out though!Really lovely build-out. Just one question (as my dealer suggested it and I'm thrilled having changed it): did you consider removing the Window Trim in High Gloss Black, since you ordered the roof rails in black aluminium and don’t have black glossy side-blades or mirrors?
In my opinion, the standard black silky window trim fits the non-glossy black parts of the car much better.
If you haven’t seen it, double-check. I went for the glossy straight away, but it was easy to convince me once I saw the “standard black matte” in my combination.
Definitely does.If it can help: I received mine last week with Bose.
It’s really not good at all. Clearly worse than the Harman Kardon in my 2015 BMW.
it’s not tragically bad, but the mids are really lacking.
I wish I would have ticked the Burmeiser
