- First Name
- Sergey
- Dec 19, 2021
- Indianapolis
- 23 Taycan Turbo, 24 Macan GTS ICE
This is certainly very unique build, and I understand the theme that OP is going for but based on other cars owned, new to Porsche option packaging. Let me unpack a couple of things that may be helpful and focus on functional elements since cosmetics and colors are personal preference.
- Base model from the packaging standpoint has the most minimal standard equipment so any option that is included or optional on higher trims will cost more. OP does not seem to be concerned with cost so that may not be relevant but wanted to point this out.
- Base from the handling standpoint has unique character with rear only motor, but from the performance standpoint it is very slow given the weight. OP says it is fast enough, but has the OP driven it to understand the dynamics of something this heavy and slow with numbers telling you everything you need to know. This will probably be the only car on the road at this price that is that slow, but understand that other things matter more.
- The other downside of the Base trim without front motor, is that there is no benefit of regen from the front axle, therefore, some rear motor regen and physical front brakes blending going on to make it seem natural, so again recommend OP driving one and understanding the braking dynamics.
- Thermal Glass main function benefit is its thickness that helps with frameless doors, so I always option it for that benefit alone, however, in terms of its thermal and noise properties those appear to be very minimal based on numbers and experiences, since the glass must allow certain frequencies such as emergency vehicle sounds to be heard.
- Drive Assist is not checked, so as long as you understand what you are missing by not optioning this, then go for not having it.
- Leather is certainly will be nicer but leather trimmed seat consoles and seat backs will be prone to scratches.
- Bose audio from my experience is about the worst in any current cars and sounds like lifeless FM reception, so BM audio will sound like an HD radio.
I am interested to see if you are going to make any changes and post revised code after forum feedback.
